Flashpro or Reflash for Kraftwerks SC?
Does Flashpro have a preloaded tune for the Kraftwerks high boost SC and is it the same tune as the Reflash? I do not want to have to tow the car to a tuner to have it tuned after installing the SC but would rather have the flexbility of Flashpro if the Reflash tune is one of the preloaded tunes on it already?
Hope my question made sense...Thanks in advance.
It may work for a completely stock setup with zero tweaks (no headers, exhaust, etc.) but you're always better off with tuning. Every car is a bit different from the next. I'm not only talking performance but safety as well.
I have heard reports that the reflash runs a bit lean around 5k but nothing alarming.
Now if you start changing things like bigger injectors, etc. even the base KW map they put out will be just enough to get you to the dyno.
The standard KraftWerks reflash is a safe, reliable, and powerful setup that has many hours of testing on it. It will tune safely for S2000 owners looking to do cat-back exhaust or no catalytic converter systems. Most of our systems have been sold this way, and are tracked heavily with no issues.
For customers planning to do big open headers, no catalytic converter, additional mod (bigger TB, intake manifold, etc.) systems, we recommend custom tuning with the FlashPro and our KraftWerks YouTune system. The FlashPro covers the custom builds we cannot cover with a reflash, but requires tuning from your local tuner.
If you are all about adjustment and tuning, the FlashPro is the direction to go. It will come with a boost map that will get you started and to the dyno. The actual KraftWerks reflash is not available on the FlashPro.
-Oscar Jr.
-Oscar Jr.
