Fpro tuned 08 CR with Toda C Cams
Here is a recent Toda C cam install dyno:
Owner: Kevin aka kevs2kcr
Car: 08 CR
Mods:
-Toda header
-Toda test pipe
-Toda 60mm Dolphin exhaust
-Toda C's (thanks to Bulletproof Automotive)
-Hondata Flashpro (thanks to Hondata)
-Everything else stock
Write up in the N/A Forums
Car: 08 CR
Mods:
-Toda header
-Toda test pipe
Originally Posted by Harpoon,Jan 19 2010, 07:37 PM
Was the sniffer in the tailpipe? That often leads to a leaner than reality reading.
This is the closest file we could find that could be used for comparison.
Stock AP2 (red) vs Hondata Reflash/ASM header/test pipe/Invidia V2 dual/HKS Supermegaflow drop in filter/Hondata heatshield gasket. Pretty similar to the graph on Hondata's page with yields in the midrange. Sorry the viewer only allows for three comparisons if one of the files is live.
Originally Posted by BlackTrax,Jan 19 2010, 09:08 PM
Dyno's wideband was in the tail pipe. Fpro was logging the OEM sensor about 1 AFR richer.
do you have a final a/f log of the final run?
