Custom Sector One Design / Pro Autosports SC build
Old Jan 29, 2010 | 09:02 PM
GEARHEAD's Avatar
Default Custom Sector One Design / Pro Autosports SC build
Custom supercharger build – AP1
Designed and Fabricated by Sector One Design / Pro Autosports Inc
Design goals:
-Minimize weight and complexity
-Minimize charge pipe length, volume, and efficiency – enhanced throttle response
-Optimize intercooler design: size, location, and flow distribution
-Keep mass centralized and as low as possible
-Complete bolt-on – no cutting or drilling
-Track ready
Execution:
-Rotrex C30-94 compressor @ 10psi mounted in AC compressor location - laser cut and tig welded stainless steel mounting bracket
-V-mount radiator/intercooler – ambient air to rad and IC, no restrictions, custom radiator using C&R core
-Hybrid "vertical flow" intercooler with carbon fiber end tanks – end tanks optimized for flow distribution using CFD and flow bench testing - intake temperatures are extremely low
-Mocal laminova oil cooler
-Short aluminum charge pipes
-SC oil reservoir mounted in grill for air cooling
Peripherals:
-AEM F/IC
-ID 725 injectors
-Walbro 255 fuel pump
-Synapse Synchronic BOV
-Prototype anti-fuel starve accumulator
Still to do:
-Final dyno tuning – currently road tuned and runs very well
-Plumb BOV for recirculation
-Crankcase breather/catch can
-Final finish on IC endtanks
-IC exhaust ducting
I'll update with dyno results but I expect them to be similar to an AP1 High Boost KW system. This application is being conservatively tuned for continuous track abuse.
Old Jan 29, 2010 | 10:05 PM
smirfs2k05's Avatar
Very nice, minus no A/C lol
Old Jan 31, 2010 | 10:07 AM
SLINKYDOG's Avatar
looks nice jared.
accumulator location?
Old Jan 31, 2010 | 12:38 PM
dimi's Avatar
Looks awesome, minus the AEM F/IC!
Old Jan 31, 2010 | 06:54 PM
ILoveMYHonda1984's Avatar
No AC is a no go for me. I like to stay cool. Bump though for another Rotrex powered kit!
Old Jan 31, 2010 | 07:46 PM
GrandMasterKhan's Avatar
Sweet. I LIke!
Old Feb 1, 2010 | 08:29 AM
CourageOO7's Avatar
Correct me if I'm wrong, but, are you going to do something about the lack of flow through the intercooler? Without a larger vent in the hood, there's no negative pressure gradient on the outlet side of the intercooler to increase flow and cool the charge. I imagine the air flowed into the front side of the intercooler has nowhere to go other than around the intercooler rather than through it.
Old Feb 1, 2010 | 09:01 AM
psileepr's Avatar
Great looking kit. The CF endtanks are sexy.
My only concern would be the placement of the Rotrex reservoir. With it mounted up front like that I would be concerned that road debris may puncture the lines or make a nice big hole in the side of reservoir itself. Since that is your SC's lifeblood any damage to that reservoir = buy another SC which would suck.
Old Feb 1, 2010 | 09:29 AM
Slows2k's Avatar
Where is the air filter?
Old Feb 1, 2010 | 10:19 AM
that tank would only be damaged if the car was in a crash. Sure it will get chipped up from small rocks since its aluminum, but no way it will get punctured.
