Still have an idling problem . . .
Old Apr 12, 2010 | 06:56 AM
J-rod's Avatar
Default Still have an idling problem . . .
When I get out of gear, and go into neutral as I'm coming to a stop, the RPM's drop to almost zero, and sometimes the car stalls out . . . If I shut off the car, and restart it, the car will idle fine until I get back into gear and drive for a bit, as soon as I go back into neutral, it happens again.
I've replaced the spark plugs, MAP sensor, and idle air controller valve . . . and I still have this idling problem . . . it might have even gotten worse!!!
What else could be the problem? I haven't been able to detect any vacuum leaks, but I supposed there could still be one somewhere. Could it be the injectors?
The car is going to be parked for 3 months this summer and if I don't get this problem resolved before then, I'm probably just gonna sell the damn thing.
Any help would be greatly appreciated!!
Old Apr 12, 2010 | 07:41 AM
fivlemon's Avatar
did you clean the map sensor channel through throttle body?
Old Apr 12, 2010 | 08:21 AM
J-rod's Avatar
No, this could be what I try next though
Old Apr 12, 2010 | 08:27 AM
fivlemon's Avatar
you should try it, my similar problem was solved after doing this
Old Apr 12, 2010 | 08:37 AM
RockyMountainS2k's Avatar
I few friend with s2000's put in the t1r voltage stabilizer and that seemed to help with this problem. though there cars never stalled out...
Old Apr 12, 2010 | 10:08 AM
turbo_slug's Avatar
check the throttle position sensor?
Old Apr 12, 2010 | 10:57 AM
MasterForce's Avatar
i get that too but i think its my cat getting clogged up. i guess not enough back pressure. once i install my test pipe we will see if that was the problem.
Old Apr 14, 2010 | 11:59 AM
J-rod's Avatar
I already have a test-pipe on my car . . . so I don't think that's it.
The car runs fine in gear, and has no problems . . . it is only when I go into neutral after coming out of gear.
I don't know if it's not getting enough air or fuel or what . . .
I've read that Injectors could cause this, but I'm not getting any misfire codes or anything
. . . got a suggestion to get some carb cleaner, spray it in there, and see if maybe it'll clear up some crap that might be clogging it up
Old Apr 14, 2010 | 01:07 PM
eric1234's Avatar
I don't know if it's applicable for the S2000, but in my '01 Mazda Protege, similar symptoms were related to the EGR valve sticking...
Old Apr 14, 2010 | 01:24 PM
Slows2k's Avatar
No S2000 has ever had a EGR valve.
