Hoang's DIY UKDM Fog Light Installation
Rear Fog Light Installation DIY (1st attempt)
Time:
It took me about 7 hrs more or less lol start to finish
What you'll need:
• Wire stripper/crimper
• Fuse holder (mini preferable)
• Fuse 15AMP (mini)
• Rocker LED switch or regular switch without LED
• Flex tubes
• Zip ties (black preferable)
• 16 gauge wires (choose 3 different color preferable)
• Ring terminal 16Ga (ground)
• Terminal connector male & female 16Ga (power/load)
• Electrical tape
• 30 AMP relay
The Fog Light
- AP1 rear bumper has the cut out for it. Luckily for me, L-X hooked me up with one that didn't have wires cut out and the plug is still intact.
The Switch with LED Indicator
- you can find it at auto hardware stores
Remove Rear Bumper
- AP1 to AP2 Rear Bumper Conversion
Fortunately for me, I already had the pig tail to connect directly to the fog so all I had to do was connect longer wires (ground & power) so it can go from the rear to the front (pig tail for the plug is purchasable at the dealer! FYI).
I chose to use terminals connector to connect the wires because I put a LED bulb instead of the regular one. The ground (black wire) and power (red/orange) wires must be switched for the LED bulb to work (connect the opposite way, black goes to power while red goes to ground)
Wires go thru the same tube where the license plate plug goes.
Spot to connect ground.
This is to show where you can have the power (red) wire follow thru.
Here is where the power (red) wire comes out, right behind the driver seat near the door.
I wanted to check that everything was working fine before continuing so I plugged everything up. You can see the switch, fuse & on the carpet right by the seat, the relay.
The under dash fuse box has 3 accessory connectors, I chose ON with LIGHTS for the fog light and ON always (constant) for the switch. I assume you can just t-tap the switch power cable with the fog light to the ON with LIGHTS connector (correct me if I'm wrong).
Next is wiring the relay to the switch and I decided that I wanted the switch inside the center console so I ran the wires (ground, power & load) back around behind the seat to the secret compartment area.
Then I went back and started to tape, zip tie, and flex tube the wire together for a cleaner look.
The result with hiding everything inside the flex tube!
There are two screws that hold the pull switch for the trunk, I chose the lower one to hold my relay and the upper one to ground the relay and the ground wire coming from the switch.
FINAL RESULT
- the light output with the LED bulb is about the same as the rear tail light when on.
DO NOT DO THIS
- I made a mistake by not looking further out when it came down to the switch, I wanted to wire it in the rear of the cup section but there is no room behind it for the switch extend out (can't even reinstall the console lol). I should've chosen the FRONT instead!
Helpful Links
Adding DRLs (Daytime Running Lights) to a US-spec S2000
European OEM AP1 rear fog light, Finally installed
From Detroit to Amsterdam - Completed!
Rear Fog Lamp
What would it take to get the Euro-spec rear fog light onto our cars?
Light in middle of rear bumper (Euro Models) installation
Cusco/Safety21 5 point roll bar installation!, Step-by-step Writeup with many pictures
Installation of Raybrig rear fog light, need help with wiring
Rear Fog Light Issue 99-03, One for the FAQ
Need Bulb Size, Don't Have Owners Manual
Non S2Ki Links
How to - JDM ITR HID Headlight and Fog Light Wiring
Wiring JDM fogs w/toggle&Relay
G3 Factory Fog Light Wiring
DIY: DRL's & Low Beams (No Switch)
Shout Outs to
s2kdriver80
lawliver
m3bmwcab
Garage R
L-X
& S2Ki
Time:
What you'll need:
• Fuse 15AMP (mini)
• Flex tubes
• Electrical tape
• 30 AMP relay
Originally Posted by NVMY4N
DISCLAIMER - I do not guarantee any procedures or products that are demonstrated here are the best for your car as I cannot control your circumstances.
So if you screw something up - it's not my fault.
Remove Rear Bumper
FINAL RESULT
DO NOT DO THIS
Helpful Links
Rear Fog Lamp
Non S2Ki Links
Shout Outs to
s2kdriver80
lawliver
m3bmwcab
Garage R
L-X
& S2Ki
so this is a third light tied to the rear backup lights? good idea, i thought you were going to use a real fog light, the second attempt are you going to go with yellow or white (rather than red)?
For me it's just for look or I guess an additional light to the rear but if I would have chosen to use the OEM bulb it'd be brighter, probably as bright as the brake light or brighter. I've always liked fog light kit from Honda =P. I know you can find cheap fog light set and fabricate like how some truck or trailer has.
