Just found on magnetic drain plug
Old Jul 30, 2010 | 10:55 PM
sworks's Avatar
Default Just found on magnetic drain plug
Help,
I just drained my oil and found this bolt attached to the end of my magnetic drain bolt. I have scoured my Helm's manual and cannot figure out where it goes or came from. It measures 14mm long x 5mm in diameter, has 2 holes near the threaded head and appears to have a spring in the shaft with a ball bearing in the tip. At first I thought it was an oil jet bolt but it has an allen head rather than flared nut. The car is a 2006 AP2. Did Honda change the bolt and this is an oil jet bolt? Also, this bolt came out in perfect shape and there were no shavings on the magnet and no other metal showed up in the drain pan.
Thanks,
Steve
Old Jul 31, 2010 | 12:59 AM
SpitfireS's Avatar
That's from your Timing Chain Tensioner.
And it's bad news you found in your oil pan!
It's supposed to be in the threaded hole with the 2 dimples.
(at 7 o'clock.. in the picture)
I guess its time to remove your TCT and:
#1 put it back in and re-do the dimples - with a small punch.
(I wouldn't use Loctite as that bolt is a valve with a small ball & spring and the Loctite may end up in the valve or in an oil line in the housing unless you know how to handle Loctite.)
#2 get a new TCT if you don't trust it.
Old Jul 31, 2010 | 01:44 AM
realblag's Avatar
wow............you just dodged a bullet. My t-chain prolly would have flown through the hood if that happened to me. No point in buying a lotto ticket or anything. All your good luck just got used up for a while.
Old Jul 31, 2010 | 01:53 AM
s2image's Avatar
yeah, that thing is from the TCT.
Happened before.
https://www.s2ki.com/forums/index.php?showt...&#entry18200370
Old Jul 31, 2010 | 07:12 AM
ans2k's Avatar
How does this thing "just fall out"? Should everyone be concern?
Old Jul 31, 2010 | 07:20 AM
camuman's Avatar
WOW. i was gonna say TCT but everyone beaat me too it. that sucks dude.
Old Jul 31, 2010 | 08:12 AM
ChefJ's Avatar
good news is it probably just fell straight down into the oil pan without contacting much.
Old Jul 31, 2010 | 10:03 AM
vtec4life57's Avatar
id just replace the tct.
Old Jul 31, 2010 | 03:41 PM
sworks's Avatar
Thanks for all the help. That's exactly what it was but not from the TCT I had installed. It was from the one just replaced. I had the car in for some work and the when they finished the car started making the TCT's gone noise. I went and grabbed one for him to replace. He must not have noticed that bolt gone.
Old Jul 31, 2010 | 04:45 PM
nartnailuj's Avatar
There's no way to find out if my bolt fell off my TCT? I'm not having any TCT ticking noises.
