Who wants more BOOST from VORTECH???
We are a demand driven company and I wanted to know who(if anyone) was demanding more boost. We would be willing to make smaller pulleys if people were interested. This would NOT be an official Vortech upgrade. It will NOT be in kit form. We are simply making a part you can buy to make MORE POWER
Just a warning: if you decide to increase the boost you should add injectors, tuning and other things to make the motor safer under high boost. The charger/aftercooler setup can make a lot more power but the high compression motor is going to be your limiting factor. increase boost at your own risk
That being said, how much more boost do you want??
For example, +2psi,+3psi ect...
Trevor
That being said, how much more boost do you want??For example, +2psi,+3psi ect...
Trevor
The pulley size would depend on how many more psi you wanted. We would have to do some calculations to figure that out. I was just trying to collect some info so that we make what you need. Thanks.
Trevor
Trevor
more is always better. i am sure people would like a range of pulleys. Guys would wanted to change internals could get a pulley that doubled the boost ect. I can't believe a pulley would be that expensive to make. I think a whole line of pulleys would be cool.
Originally posted by StormBringer
Silly question what psi does this specific supercharger top out at rpm dependent, as the S spins very high it would be interesting to see the max PSI of the unit.
Trevor I would like to up the boost on my Vortech kit by 2 psi sometime in the near future.
I would like 10psi before the cooler and 8psi after. That would also probably bring the boost at 4000 up from 1psi to about 2psi which would be really nice.
Name your price, I want whatever size it would take to do that. I think anything more than that, and I will have to go to a stand alone fuel management system, new injectors, pistons/compression ratio, etc, and I don't know that I want to go down that path(yet
