Mark this thread as Sold
Tons of OEM parts. Click my ebay link for parts and pics
Old Sep 3, 2010 | 08:22 AM
Quivers's Avatar
Banned
Default Tons of OEM parts. Click my ebay link for parts and pics
Hello, my name is Dan
I'm located in Plainfield , IL
Please text me for pictures and questions, I'm extremely busy with service work at the shop!!!
EBAY STORE <<< Pics and prices here, text me for a better price off EBay.
EMAIL DanRiversJr@gmail.com <<<<also my paypal address
TEXT 630-957-8798
ebay listings
Pictures are in the ebay listings.
Parts below are from my most recent 03 yellow with 55k miles all parts clean.
Description: Our Price Shipping
Coolant reservoir 20 10
Propeller shaft 80 30
Passenger axle SOLD
Driver axle SOLD
Fuel pump assembly 60 10
Serpentine belt tensioner 35 10
Alternator 40 10
Shifter set 55 10
Idle air control valve SOLD
Evap canister 20 10
Coil pack cover 25 10
Fuel injector set SOLD
Throttle body w/ map and tps sensor SOLD
Transmission mount 40 10
Softop strikers SOLD
Coil pack (099700-0430) SOLD 10
EPS unit 60 10
Brake proportioning valve 20 5
Driver front caliper 40 10
Passenger front caliper 40 10
Passenger rear caliper 40 10
Driver rear caliper 40 10
Gas pedal w/ throttle cables 40 10
Brake pedal w/ sensors 40 10
Clutch pedal w/ sensors 40 10
Aluminum dead pedal 20 10
Driver rear shock 50 15
Passenger rear shock 50 15
Driver front shock 50 15
Brake booster 40 10
Wiper+Turn signal stalks 30 10
Secondary air valve assy. SOLD
Shift knob (Scratches) 35 10
Hood pop handle
Fuel filler door (Spa yellow) 30 10
Radio door 35 10
Interior light 20 10
Fuel filler cap 15 10
Door sensor 15 5
Door sensor 15 5
Convertible top switch 15 5
Wiper arms 25 10
Horn 20 10
Side marker 20 10
Intake manifold SOLD
Coolant temp sensor 15 5
Horn 20 10
Shift fork SOLD 10
Engine bay heatshield 25 10
Radiator cap 15 5
Driver rear ABS sensor 40 5
Passenger rear ABS sensor 40 5
Upstream o2 sensor SOLD 10
Downstream o2 sensor SOLD 10
Tool set 45 15
Antenna kit w/ wiring 40 10
Trunk light with bulb 40 10
Front roof rail garnish 25 20
Driver A-piller cover 20 10
Passenger door sill 20 10
Driver door sill 20 10
Driver side cowl garnish 25 10
Passenger side cowl garnish 25 10
Driver rear garnish 20 10
Passenger rear garnish 20 10
Passenger rear convertible top garnish 20 10
Driver rear convertible top garnish 20 10
Passenger console cover 60 10
Driver console cover
Exhaust manifold 50 25
Parking brake lever 30 10
Rear swaybar 40 20
Rear swaybar endlink 15 5
Front swaybar 40 25
Front swaybar endlink 15 5
ABS modulator 50 10
Brake master cylinder 60 10
Air pump w/o bracket 80 10
Starter 45 10
SRS cable reel 25 10
Wiper motor w/ levers 40 20
Top cowl assy.
Water pump 25 10
Coolant hose junction SOLD
Rear skid plate 15 10
Rear console box 75 20
Passenger knee panel 15 10
Passenger front ABS sensor 40 5
Battery tray w/ base 20 10
Engine mounts
Fuel pressure regulator 35 5
Fuel feed line 15 10
Injector cover 15 10
Thermostat w/ water pump housing 40 10
Hood prop 20 10
Below is a list of parts I have from past part outs and none of the parts from the above car.
Description Fitment Price and second number is shipping cost
Driver rear upper control arm Ap2 $50 $15
Driver front upper control arm Ap1/Ap2 $50 $15
Passenger front upper control arm Ap1/Ap2 $50 $15
Driver rear upper control arm Ap1 $50 $15
Passenger rear upper control arm Ap2 $50 $15
Driver rear lower control arm Ap1/Ap2 $70 $20
Driver rear toe-arm Ap1/Ap2 $35 $15
Passenger rear toe-arm Ap1/Ap2 $35 $15
Passenger rear shock Ap2 $45 $20
Driver rear shock Ap2 $45 $20
Passenger front shock Ap2 $45 $20
Driver front shock Ap2 $45 $20
Driver front knuckle Ap1/Ap2 $70 $20
Passenger front knuckle Ap1/Ap2 $70 $20
Rear Sway Bar 27mm $40 $10
Front Sway Bar 27mm $40 $10
Alternator Ap1/Ap2 $55 $15
Starter Ap1/Ap2 $50 $15
A/c compressor Ap1/Ap2 $55 $15
Water pump Ap1/Ap2 $40 $10
Water cover Ap1/Ap2 $25 $5
Serpentine belt tensioner Ap1/Ap2 $20 $10
Secondary air valve assy. Ap1/Ap2 $40 $10
Front subframe Ap1/Ap2 $150 Freight
Rear subframe Ap2 V1 $150 Freight
Rear subframe Ap2 V2 $150 Freight
Brake master cylinder Ap2 V2 $50 $10
Brake master cylinder Ap1/Ap2 V1 $50 $10
Master power set Ap1 $30 $10
Master power set Ap2 $30 $10
Driver front caliper Ap1/Ap2 $30 $10
Passenger front caliper Ap1/Ap2 $30 $10
Driver rear caliper Ap1/Ap2 $30 $10
Passenger rear caliper Ap1/Ap2 $30 $10
Clutch master cylinder Ap1/Ap2 $50 $10
Propeller shaft Ap1 $80 $20
Propeller shaft Ap2 $80 $20
Dashboard Ap1/Ap2 $150 Freight
Driver vent set Ap1/Ap2 $20 $5
Turn signal stalk Ap1/Ap2 $25 $8
Wiper stalk Ap1/Ap2 $25 $8
Driver front ABS sensor Ap1 $45 $5
Passenger rear ABS sensor Ap2 (2004) $45 $5
Passenger rear ABS sensor Ap1 $45 $5
Driver front ABS sensor Ap2 $45 $5
Passenger front ABS sensor Ap1 $45 $5
Convertible top with frame (glass) Ap1/Ap2 $850 $100
Driver door sill Ap1 $20 $10
Passenger door sill Ap1 $20 $10
Passenger door sill Ap2 $20 $10
Interior garnish Ap1/Ap2 $25 $10
Cd changer cover Ap1/Ap2 $25 $5
Passenger kick panel Ap1/Ap2 $25 $10
Driver kick panel Ap1/Ap2 $25 $10
Rear driver convertible garnish Ap1/Ap2 $25 $10
Main engine wire harness Ap1/Ap2 V1 $140 $10
Dashboard wire harness Ap2 V1 $75 $10
Cabin wire harness (left) Ap1/Ap2 V1 $75 $10
Passenger rear garnish Ap1/Ap2 $25 $10
Passenger knee panel Ap1/Ap2 $25 $8
Driver knee panel Ap1/Ap2 $25 $8
Passenger A-piller Ap1/Ap2 $25 $10
Exhaust manifold Ap1/Ap2 $70 $30
Differential mount set Ap1/Ap2 $25 $10
Engine control unit Ap1 $40 $10
Engine control unit Ap2 $40 $10
Rear differential mount set Ap1/Ap2 $30 $10
Rear differential mount (left) Ap1/Ap2 $30 $10
Fuel rail Ap1 $40 $8
Fuel rail Ap2 $40 $8
Evap canister Ap1 $40 $10
Evap canister Ap2 $40 $10
Intake manifold Ap1 $50 $15
Shift lever set Ap1/Ap2 $65 $8
Shift fork Ap1/Ap2 $30 $5
Engine oil cooler Ap1/Ap2 $50 $10
Windshield washer reservoir Ap1/Ap2 $25 $10
Column with 2 stalks Ap1/Ap2 $15 $10
Hazard switch Ap1/Ap2 $10 $5
Passenger window switch Ap1/Ap2 $10 $5
Trunk release switch Ap1 $15 $5
Parking brake lever Ap1/Ap2 $20 $8
Plastic under gas pedel Ap1/Ap2 $5 $5
Plastic under steering wheel Ap1/Ap2 $25 $10
Foot vent Ap1/Ap2 $15 $10
Speaker cups Ap1/Ap2 $25 $5
Dome light Ap1/Ap2 $15 $5
Door speakers Ap1/Ap2 $25 $10
Clutch pedel Ap1/Ap2 $15 $10
Brake pedel Ap1/Ap2 $15 $10
Cup holder Ap1/Ap2 $15 $8
Injector cover Ap1/Ap2 $15 $8
Cargo net plugs (Red, 4) Ap1/Ap2 $10 $5
Cargo net (Black, small) $15 $5
Cargo net (Black, large) $15 $5
Airbag $75 $20
Center interior garnish Ap1/Ap2 $25 $10
Vtec solenoid Ap1/Ap2 $80 $10
Oil pressure switch Ap1/Ap2 $15 $5
Water temp sensor Ap1/Ap2 V1 $10 $5
Intake air temp sensor Ap1/Ap2 $15 $5
Valve assembly purge control Ap1/Ap2 $15 $5
Bypass control solenoid Ap1/Ap2 $15 $5
Rotary air control valve Ap1/Ap2 V1 $15 $5
Door sensor Ap1/Ap2 V1 $15 $5
Door sensor Ap2 V2 $15 $5
Map sensor Ap2 V2 $15 $5
Fuel pressure regulator Ap1/Ap2 V1 $20 $5
Windshield washer pump Ap1/Ap2 $10 $8
Convertible top motor (right side)Ap1/Ap2 V1 $30 $10
Clutch slave cylinder Ap1 $40 $8
Clutch slave cylinder Ap2 $20 $8
Intake neck Ap1/Ap2 V1 $20 $10
Coil pack cover Ap1 $25 $10
Fuel pump Ap1/Ap2 V1 $20 $8
Abs modulator Ap1 $60 $20
Abs modulator Ap2 V1 $60 $20
Old Sep 3, 2010 | 09:42 AM
gh0St2K's Avatar
will the '07 clutch master and slave cylinder work on an ap1?
also, do you have the silver radio door?
Old Sep 3, 2010 | 10:38 AM
Moddiction's Avatar
Hey how much for a front passenger side full fender liner part. Mine some how got loose and got shredded.
Price shipped to 10950 please. Thanks.
Old Sep 3, 2010 | 11:05 AM
marks_lude's Avatar
If the front right knuckle/hub/wheel bearing thingy is definitely from a car that was not in an accident in that corner... I'll take it for the $90 posted.
The can bend if in an accident, so I want to make sure that it is not damaged. Please let me know.
PMing you.
PS needs to be from an AP1 I think.<< Edit, nevermind, they are the same.
Old Sep 3, 2010 | 11:59 AM
Quivers's Avatar
Banned
PM's sent.
Old Sep 3, 2010 | 12:18 PM
Moddiction's Avatar
Payment sent. Thank you!
Old Sep 3, 2010 | 02:48 PM
lethals2000's Avatar
you have the front fender liners. let me know. shipped to 28023
Old Sep 3, 2010 | 04:30 PM
Jack_in_the_Box's Avatar
do u have any ap1 Passenger side headlights laying around? mine is starting to fog up from the inside.
Old Sep 3, 2010 | 04:52 PM
DPS14's Avatar
PM sent
Old Sep 3, 2010 | 06:54 PM
Quivers's Avatar
Banned
PM's sent
