Identify these wires *pics* Battery/Air Pump
Can anybody identify these wires and where they go to for me?
#1- Power wire on top of battery, i'm assuming this was supposed to go to + terminal somehow? Anybody got a pic?
#2- Theres a ground attached to the body to the left of the battery. Does anybody know where this goes to?
#3- Air Pump relay: has 2 connectors, one staring right @ ya in the picture and another underneath the relay.
#4 Wires coming from passenger side frame rail leading toward air pump. 1 Blue wire, 1 black wire, 1 large white/red wire
I just did a wire tuck / fuse box relocation this past weekend, so some of these look familiar.
#1 - You already have the same wires connected to your battery in the top pic as I do. The "power wire" you're pointing to looks similar to the ones that go into the fuse box. (Pop the top of your fuse box and right on the front edge there should be two of them.)
#2 - That ground wire probably goes into the EPS module, which normally bolts to the body in that area.
Sorry I didn't see this thread sooner when I had the car apart, or I could have answered the others.
3-EPS module? Where is that?? My power steering is NOT working right now so a missing ground could be my fix.
Bummer. Sorry, that was my best guess.
In the original location on my '03, the EPS box was bolted to the body right over that ground location beside the battery / behind the fuse box. The ground wire itself is less than a foot long and comes out of one of the EPS box connectors, does a 180 and then bolts to the body. Can you trace where that wire's going, and/or post more pics of the general area? Then we'll know if I'm wrong with this guess too.
If you do a search for wire tuck or fuse box relocation, you'll find several good threads with various pics of the wiring harness and this area. Some might show what you are looking for.
08s2000CRbackinblack
May 8, 2010 02:45 AM
