Very loud squeaking noises in Pass. Rear
Started 4 days after an autocross event, Was once a low squeaking noise has gotten louder and louder. I took off the tire and re-greased and re set the brakes but that was no help. Don't know what to do from here, my car sounds like a hoopty. I know for sure it is coming from the passenger rear wheel area.
Any solution a jar of grease can fix?
to me it sounds like the dust sheild is hitting the rotor. This happened on my car due to the camber adjustment arm having excessive play which pushed the shield into the rotor causing the same type of noise.
I would jack up the rear of the car and spin the wheels, see if it does it then. take the wheel off and spin the rotor, take the caliper off and spin the rotor, just keep eleminating things it could be until the noise changes or goes away.
Ever fix the problem??
Yeah i know, almost 1 year later bringing the thread back from the dead..
I have to jack up my car and spin the tires with the gas and pinpoint the sound, but i think its the wheel bearing
ultimaRicer
Nov 24, 2012 05:00 AM
Pink Lady
Nov 18, 2003 11:09 PM
