Sponsored by:
Sponsored by: Sake Bomb
ABS light come on after adding camber kit.
Old Oct 17, 2010 | 04:34 AM
sata3000's Avatar
Default ABS light come on after adding camber kit.
I installed a rear camber kit on my car after dropping it a inch.. Ive had my car lowered for about 2 months before I installed camber kit. As soon as I installed caber kit my ABS light stays on. I took it for a test drive and i do not have ABS. We hook it up to a scanner and its telling me right rear sensor. Do you all think replacing this sensor with fix my issue?
Old Oct 17, 2010 | 03:03 PM
Uncoolron's Avatar
Yes. But I don’t think camber kit has anything to do with it unless the ABS sensor was some how hit during installation.
Old Oct 17, 2010 | 03:22 PM
9k_on_occasion's Avatar
Try plugging it back in. That, or take it off and clean it up.
Old Oct 17, 2010 | 03:42 PM
GetS2pd's Avatar
If you put ANY stress on the wires, there's a good possibility that there's now an open. You can use an ohmmeter and check the sensor - it should read between 450-2K ohms.
If it looks like a bad sensor, swap it with the left rear and see if the code follows. If you were local, I'd ohm it out for ya'...
Old Oct 17, 2010 | 03:50 PM
Slows2k's Avatar
You most likely broke the sensor wire internally when you installed your camber kit.
Old Oct 18, 2010 | 10:16 AM
sata3000's Avatar
thanks for all imput. new sensor in the mail will be able to give results within a week.
thanks again
wazpe
Jun 20, 2022 01:36 PM
sata3000
Oct 20, 2010 05:49 AM
R1_Pilot
Jun 22, 2010 11:26 AM
hornyhonda
Jul 29, 2004 07:40 AM
