ABS light come on after adding camber kit.
Old Oct 17, 2010 | 02:41 PM
sata3000's Avatar
Default ABS light come on after adding camber kit.
Original post
https://www.s2ki.com/forums/index.php?showtopic=823734
Old Oct 17, 2010 | 03:48 PM
GetS2pd's Avatar
If you put ANY stress on the wires, there's a good possibility that there's now an open. You can use an ohmmeter and check the sensor - it should read between 450-2K ohms.
If it looks like a bad sensor, swap it with the left rear and see if the code follows. If you were local, I'd ohm it out for ya'...
Old Oct 17, 2010 | 06:48 PM
sata3000's Avatar
Thanks for the imput.
Old Oct 18, 2010 | 04:57 AM
Olegator's Avatar
9 out of 10 that's what it is....
Old Oct 20, 2010 | 05:49 AM
robrob's Avatar
I had the light and it was caused by the sensor being loose. It's held into the suspension A-arm with a single 10mm bolt--mine was missing. The wire from the sensor goes up through the fender well and turns toward the front and after a couple of inches there is a connector. Check the connector. You may be able to get to the connector by removing the spare tire. The connector is attached to the right wall just beyond the spare tire's location.
If it is indeed connected and the sensor is bolted into place then it probably was damaged during the camber kit install. Don't buy the replacement until you verify it's secure and connected properly.
Rob
Si2k
Dec 12, 2011 08:14 AM
OMGJDM
Jul 15, 2011 01:13 PM
sata3000
Oct 18, 2010 10:16 AM
Asura
Aug 2, 2007 08:17 PM
Cycloneranga
Aug 19, 2006 12:03 PM
