What's the largest an AMP can be and still fit under seat?
Old Mar 2, 2001 | 07:16 PM
FRCHNDN's Avatar
I want to mount an AMP under my seat if possible. Does anyone know the max dimensions that will fit under a seat?
Old Mar 3, 2001 | 06:16 AM
RedVinesRanch's Avatar
Don't know the exact dimensions, but the floor isn't totally smooth under the passenger seat. I wanted to fit my amp under there, but no luck. It was about 8.5" x 14 inches. Ok, kinda big, but there is room, but with the exhaust indentation in the floor...
I was thinking at that time that half that size probably would have fit. I remember someone posting that they had a 25 watt amp under the seat.
Old Mar 3, 2001 | 07:01 AM
AusS2000's Avatar
First thing, you only need a two channel amp.
Second, it's not just space, you also need room for it to breathe.
This is a 35WRMS per channel amp.
If you want to install a sub later you're best off using a separate amp.
Old Mar 3, 2001 | 07:04 AM
cdelena's Avatar
You can fit a moderate sized amp in the spare..
Old Mar 3, 2001 | 08:37 AM
Utah S2K's Avatar
Most put them in the trunk.......I did see a subwoofer Amp under a stook seat in DC though. (Clarion)
Old Mar 3, 2001 | 06:21 PM
CoralDoc's Avatar
For a completely stealthy installation, I mounted my MTX 2120 (35Wx2) behind the bulhead behind the drivers seat. You can access this location by removing the spare tire cover and then removing the trunk liner to the left of that to expose the real "secret compartment". The amp fits in front of the fuel filler on the left side of the gas tank hump. I gently wedged the amp into place with some outdoor carpeting used as padding. Anything larger than this amp will not fit there.
Sieple mounted his amp in this same location, and here is a link to his picture of his installation. Scroll down to 25 February. http://www.xs4all.nl/~pwb/s2000/
Old Mar 3, 2001 | 06:33 PM
AusS2000's Avatar
My thoughts on this are: Hmmm, a high power device near the connections to the fuel tank. Maybe that's why in American movies the cars alway blow up after accidents.
Old Mar 3, 2001 | 08:44 PM
JPit's Avatar
I put an MTX amp under the driver's seat. It puts out about 75 watts rms into 4 channels (I bridged the rear two channels to the subwoofer in the trunk). I chose MTX because it was the thinnest amp I could find with the power I wanted. I think it measures about 13 1/2 X 11 X 1 1/2. The seat does not move all the way forward but 2/3s of the way which allows plenty of room.
Old Mar 6, 2001 | 04:53 PM
FRCHNDN's Avatar
This sounds like a good place for an installation. But, wouldn't an amp overheat in such a poorly ventilated area?
Was wiring easy to do?
Old Mar 6, 2001 | 05:05 PM
AusS2000's Avatar
Nah, it's got 50 litres of petrol next to it as a heat sink .
I get real worried about this installation. Fine for now, but in a few years, when seals begin to deteriorate......
