Airpump
Old Nov 5, 2002 | 07:41 PM
SsamJang's Avatar
i did a search and i just want to see if anyone else was facing similar problems like i am.. the airpump is broken and to check it i took the vaccuum line off of my Injen intake and it didnt suck air at all.. and i had my local shop take a look into all the lines to see if they were connected or not.. is this a common problem on anyones S2ks? or just a few..? im also wondering if i should buy a brand new one and have honda put it on or buy a used/salvaged part and putting it on? would this be considered under warranty? thanks
sam
Old Nov 5, 2002 | 07:52 PM
xviper's Avatar
I would think this is warranty unless you've done something to the pump that would void it.
Old Nov 6, 2002 | 05:22 AM
VTR_Gary's Avatar
The airpump doesn't suck, it's not supposed to suck anyway. It's supposed to add air to the exhaust (Using the chamber in the cylinder head which is covered by the 1 inch wide plate just above the exhaust manifold) on cold startup to help the Catalytic converter light up more quickly. The computer also makes the air pump run occasionally if th computer thinks the catalytic converter might have cooled down.
There are sensors to confirm that the airpump is doing its thing and it will trip an engine light if it's not... Do you have a check engine light on?
Old Nov 6, 2002 | 12:16 PM
SsamJang's Avatar
yeah i have a CEL on..
Old Nov 6, 2002 | 05:18 PM
VTR_Gary's Avatar
Ok. The only problem I have seen in any way related to the air pump system was the sensor that checks for air flow. It was not an easy diagnosis...
Good luck!
Old Nov 6, 2002 | 05:22 PM
SsamJang's Avatar
well i just put the stock airbox on .. and i have just resetted my battery.. and the CEL hasnt come on yet.. but im pretty sure it will.. and i made an appointment to go into the shop tomorrow
dsthez
Oct 19, 2016 10:25 PM
Nickfromny
Sep 11, 2007 04:57 AM
hondaboy82
Jun 22, 2006 07:20 PM
Hontoyo
Jan 8, 2006 09:17 AM
doriontrask
Aug 2, 2005 09:07 PM
