AHH Big window crease!!!
Old Mar 13, 2001 | 12:23 PM
Y2K1S2K's Avatar
i left my top down overnight...and put it back up today...and there is a big crease in it! i used the miata tube as well as the muz mat...is there anyway to get rid of it? like maybe use a blowdryer and heat it out? help
Old Mar 13, 2001 | 12:26 PM
SilverSurfer's Avatar
[QUOTE]Originally posted by Y2K1S2K
[B]i left my top down overnight...and put it back up today...and there is a big crease in it!
Old Mar 13, 2001 | 12:27 PM
Y2K1S2K's Avatar
im sure im not the only one with the problem...why didnt the miata tube work?
Old Mar 13, 2001 | 12:41 PM
almilli's Avatar
is the crease not centered in the window but rather at the top and/or bottom? This is because of the bars of the softtop. I made my own miata tube like contraption that has a tube with about a foot of material coming off the cylindar. I use that material to protect from those bars and from top of window to bottom of window abrasion. It's the best.
David
[Edited by almilli on 03-13-2001 at 06:25 PM]
Old Mar 13, 2001 | 01:09 PM
Y2K1S2K's Avatar
my crease is towards the bottom...and i think there is a ding there too...CRAP!
Old Mar 13, 2001 | 01:22 PM
Mack's Avatar
I've has a similar problem with the tube. Small dents on the left and the right of the window cloase to the bottom where the tube was mash between the window and top.
If you don't make sure that it is forward and actually folded in the window it tends to try and roll out of the window if this happens it will creae or dent the window where the top puts pressure on it.
Mines fine now that it's warmed up some.
Hope this help!
Old Mar 13, 2001 | 01:29 PM
lvs2k's Avatar
By using a terrycloth towel tucked under the top where it overlaps the window on the top and either side, creases can be greatly mitigated. The padding provided by the towel also helps protect against the marks caused by the top framing. I still get a little marking toward the bottom of the window; however, this falls out quickly once the top is raised. I've used the towel for over 15K miles plus the Muz mat for the last few thousand and a soft cloth in the well before that, and I have no permanent problems with the window. A good dose of Plexus applied weekly doesn't hurt, either.
Old Mar 13, 2001 | 05:24 PM
almilli's Avatar
this is what I made instead of using the miata tube. It was easy and it actually got rid of my dings and crease at the bottom of the window. I used black fleece as the fabric. And the best thing is that the tube only rolls into place when lowering the top. It never rolls out. it's great.
http://webhome.crk.umn.edu/~fredric/bolster.htm
David
[Edited by almilli on 03-13-2001 at 06:26 PM]
Old Mar 13, 2001 | 05:58 PM
Steve2K's Avatar
I has a Mustang convertible - a FORD...and never had to worry so damn much about the top or the window - sheesh! What crappy planning...and HONDA has come up with no fix of their own for this!? Shame! Shame!
Old Mar 13, 2001 | 07:44 PM
bguernsey's Avatar
I used a pool "noodle" like that but found that even when I made sure it stayed in place, the top would not retract far enough to put the boot over it. I tried a couple times with no luck.
-B
[QUOTE]Originally posted by almilli
[B]this is what I made instead of using the miata tube.
Striker
Sep 19, 2002 05:23 PM
PilotChris
Aug 8, 2002 10:52 AM
magician
Apr 15, 2002 09:30 AM
Turtle
Oct 28, 2001 03:43 AM
hpalmer
May 23, 2001 01:41 PM
