Preloading Bushings?
Old Nov 23, 2002 | 02:32 PM
Nobody's Avatar
Default Preloading Bushings?
I installed KG/MM DR21 springs a couple weeks back but did not preload the bushings before I tightened the A arms down....is this a big deal?
Thx
Old Nov 23, 2002 | 07:46 PM
VTEC Racer's Avatar
Heres what I've heard...
The bushings will get worn out quickly and handling will be effeted in a negative way. I would assume it might also mess around with your alignment. It's such a simple task, why not just do it?
Old Nov 23, 2002 | 09:58 PM
Nobody's Avatar
What's the procedure for preloading them while the car is up on jackstands?
Old Nov 24, 2002 | 12:32 AM
tothemaxx's Avatar
Yeah, would like to know too.
Old Nov 24, 2002 | 05:19 AM
cdelena's Avatar
If you tighten the components while they are drooping the bushing preload will be opposite the desired direction with some small impact on handling.
The correct procedure is to fully support the corner being tightened with the suspension before torquing to spec. While the car on on stands I put my jack under the lower control arm (using a piece of wood to protect the castle nut) and raise the corner.
Old Nov 24, 2002 | 01:11 PM
Nobody's Avatar
Done. Thanks all.
Johnmassey
May 4, 2018 04:45 AM
JamesD89
Feb 21, 2017 08:56 AM
Dembo
Jul 17, 2010 04:36 AM
nrgizeman
Jul 11, 2007 06:49 AM
JS2k.com
Feb 6, 2007 06:26 PM
