Inland Empire S2000 Owners Riverside, San Bernardino and Palm Springs area S2000 owners discussions and happenings
Need Help
Old Feb 6, 2010 | 10:15 PM
SorakS2K's Avatar
Default Need Help
Hello Guys!!!
I need help! Can't find a link to fix my keyless remote.. My car would not unlock.
I did the reprogram option like a million times still doesn't work... I tried disconnecting the battery cable, check the fuses..... no luck
Please Help! THanks in advance guys!!!
Old Feb 7, 2010 | 09:24 AM
Nis0ak's Avatar
you check the battery on the remote?
Old Feb 7, 2010 | 09:43 AM
SorakS2K's Avatar
i did..
Old Feb 9, 2010 | 11:00 AM
Black_eS's Avatar
Check the alarm unit itself? Maybe loose wire?
Old Feb 9, 2010 | 03:46 PM
tmkpres's Avatar
Im having the same problem as you man, sorry to hear. I tested eveything one by one and everything works. Just for some reason the power isnt going to the trunk release !!!!
Old Feb 9, 2010 | 07:01 PM
SorakS2K's Avatar
So, i need to change my remote battery, check fuses, check loose wire and reprogram remote... all over again????
Old Feb 9, 2010 | 07:15 PM
tmkpres's Avatar
When u push the button on ur remote do u hear a noise coming from ur dash? If you do that means its getting the signal from ur remote. Take ur trunk latch off and test it
Old Feb 9, 2010 | 07:24 PM
S2k4me2's Avatar
Isn't there an antenna under the dash for the keyless remote... I think you can put an extension on it!
I think the antenna under the drivers seat is if your car came with an alarm!
Can someone else chime in about this!
Old Feb 9, 2010 | 07:27 PM
SorakS2K's Avatar
ok... on the trunk latch how do i take it off...
Old Feb 9, 2010 | 07:43 PM
FilthyAp2's Avatar
Pat if the car has the factory alarm installed then the antenna is under the driver seat......
If you only have the keyless entry from factory then the antenna is under your dash (it's a plate) and you would have to soder wire to it and run it.
I really doubt it's a antenna issue but that's just me.
Check your fuses and chase every wire if you have a diagram. My guess is that a wire is not making good ground/connection.
GL
Jc
