compression test?
Old Feb 26, 2009 | 11:28 PM
agentRak's Avatar
Default compression test?
what kind of numbers should i expect?
Old Feb 27, 2009 | 11:00 AM
negcamber's Avatar
Primary thing is to make sure the numbers are consistent across all 4. Depending on the compression tester used you can see anything between 150-230psi. Not all gauges are calibrated the same.
Old Feb 27, 2009 | 01:49 PM
agentRak's Avatar
So you are saying only reason I might have lower compression psi is due to comment above? I thought It should be somewhere between 200 to 240, isn't 150 too low? I would expect b18 motors to be around 150 to 170 psi.. then again I don't know what i don't know.
Thanks!
Old Feb 27, 2009 | 03:10 PM
negcamber's Avatar
Helm's manual says:
Nominal = 228 PSI
Minimum = 135 PSI
Max variation = 28 PSI
amelite
Jan 12, 2010 03:37 PM
teddy11
Mar 4, 2009 06:24 PM
mxt_77
Jul 19, 2004 08:26 PM
