F.N.G
Old Jun 27, 2018 | 06:53 PM
Mcat069's Avatar
Default F.N.G
Greetings all, just got an 05 with 88k and thought this would be a good forum to gain some knowledge.
Old Jun 28, 2018 | 05:10 AM
Mcat069's Avatar
It's actually paved, the dirt is my piss poor lawn lol. And nothing stays clean in West Texas.
Old Jun 29, 2018 | 09:24 AM
IA-SteveB's Avatar
Is the hood all oxidized or am I seeing a reflection?
Old Jul 2, 2018 | 07:43 AM
Mcat069's Avatar
It's actually an aftermarket carbon fiber hood that I think looks terrible. I think the kid I got it off of was in The Fast and Furious fan club. It also has a CAI and I think aftermarket headers; I don't know what came stock.
Old Jul 2, 2018 | 07:47 AM
TsukubaCody's Avatar
The DC sports header is fine, it won't gain you any power, but the quality is probably okay. It isn't doing you any harm. K&N intake is a decent piece, filter looks like it might need clean/oiling? I would just paint that hood if I were you.
Welcome.
Old Jul 2, 2018 | 08:36 AM
Mcat069's Avatar
Welcome.
I am a novice when it come to body work and painting. In your experience, could I paint it myself or would I need to take it to a shop?
Old Jul 2, 2018 | 10:03 AM
Mcat069's Avatar
Originally Posted by Deckoz
Hey there, So you could actually wet sand that carbon hood pretty easily, I would remove it and place it on saw horses.
As far as after it is cleaned up - take it to a body shop and have them either clear coat it, or paint match.
The filter needs power washed and re-oiled, but it also looks like it is the wrong filter. So I would verify the part number from the AEM kits, and double check it against your's.
The DC header - as another mentioned isn't doing you any harm. If you really wanted, you could drop the header, sand or bead blast it, and then have it ceramic coated if you are concerned about it rusting over time. Also I would try to source the OEM Body Heat shield, so you aren't heating your refrigerant lines and fuseboxes, should fit just fine with the DC header in there. You can see the Body heat shield in this picture
As far as the rest of your paint - it looks like a good wash, claybar and a polish would do it some good. I still see plenty of shine from your further back pictures, just needs a good detail
FYI I am not sure if you noticed, but your valve cover has oil creep, likely valve cover gasket needs replaced, and the upper and main VTEC gasket are leaking. As you can see the front side of the block by the VTEC solenoid has grime build up. A citrus degreaser and a parts brush will make it look good as new
Hope you don't take any of what I mentioned above the wrong way - just trying to help what I noticed.
Thank you for your suggestions. The replies I have gotten are actually why I joined this forum. Is it a terrible pain in the ass to change the leaking gaskets? This is the first import car I've owned; my daily is a 3/4 ton 8.1L Suburban lol. It's 496 is a completely different animal.
Old Jul 2, 2018 | 10:38 AM
I'm not a bodywork guy, I'd take it to a shop to have it match the rest of the car.
kdoggx2o00
Sep 28, 2009 11:26 AM
Emoore
Nov 13, 2008 10:23 PM
s2k11
Feb 11, 2007 03:17 AM
crownhondatech
Sep 26, 2005 05:05 PM
