HID problems
Old Feb 1, 2019 | 08:11 PM
Craft-S2K's Avatar
Default HID problems
Hey guys,
It raining hard and my driver side HID went out. I thought it was the bulb so I bought new Osram D2S bulbs, still didn’t work..
I replaced the control ballast with a brand new OEM now the light flickers and turns off within 5 seconds.
I double checked all the connections everything seems in contact.
I haven't switched headlights to see if it works on the passenger side yet.
Anyone have this issue? Help please.
Kenny
2008 S2
Old Feb 2, 2019 | 01:20 AM
Say Chi Sin Lo's Avatar
Swap parts between the passenger side (still functioning) until you can isolate the source of the problem.
Old Feb 2, 2019 | 05:07 AM
Chuck S's Avatar
Does the wattage of the bulb matter? The OE HIDs are 35w. Not sure if a higher watt bulb would cause this effect.
-- Chuck
Old Feb 2, 2019 | 10:20 AM
-- Chuck
If it's an Osram, which is an OE supplier, then it won't be 55w as OEM specs are 35w.
Try switching the passenger side (functioning) ballast over to the dead driver side. Flickering light suggests a dead ballast.
Old Feb 2, 2019 | 07:52 PM
Craft-S2K's Avatar
Thanks, I’m going to remove my bumper and switch headlights to see if I still have the same problem.
To be continued..
-Kenny
Old Feb 2, 2019 | 09:37 PM
Langelo DeMysterioso's Avatar
Very interesting
I have this issue...
Old Feb 3, 2019 | 08:18 AM
Craft-S2K's Avatar
[left]I have switched the headlight from driver side to passenger side. The HID is working properly on passenger side. Problem is in the driver side
Old Feb 3, 2019 | 12:03 PM
What do you mean you switched the "headlight"...
Old Feb 3, 2019 | 12:53 PM
Craft-S2K's Avatar
I removed the driver side headlight and installed it on the passenger side.
It was the driver side fuse that was bad. I also replaced the headlight rubber boots. Everything is working now.
Thanks for the help.
-Kenny
Old Feb 3, 2019 | 12:56 PM
davidc1's Avatar
Now switch the ballast.
