I JUST GOT MY s2k!
Old Oct 9, 2009 | 01:29 PM
drchux's Avatar
Default I JUST GOT MY s2k!
hi guys!!! ... i just got my 2003 s2000 with skunk2 and K&N filter
69000 miles on it.... what to do fisrt?? timing belt? water pump?
Thanks =) im so happy haha
Old Oct 9, 2009 | 01:33 PM
zachismisitok's Avatar
what to do first? learn to drive it
driver mod >>>>>> other mods
go get yourself some track time
maintnence wise, I would set it on some stands and do the engine oil, tran. fluid, and diff all at once. Then replace air filter and spark plugs. then check pads. The get someone to teach you how to do the valve adjustment
Old Oct 9, 2009 | 01:36 PM
Stealth_SUX_'s Avatar
No need to do timing belt, because its a timing chain.
If u change plugs, make sure u go ONLY with OEM spark plugs.
Check you in cabin air filter, its probully never been changed.
Old Oct 9, 2009 | 01:48 PM
drchux's Avatar
thanks for the fast response!, what oil do you guys recomend?
Old Oct 9, 2009 | 01:53 PM
drchux's Avatar
Image and video hosting by TinyPic
what oil you guys use?
Old Oct 9, 2009 | 01:54 PM
drchux's Avatar
Old Oct 9, 2009 | 03:13 PM
detonator2x's Avatar
Learn proper jacking points
Find the gas door popper
Find the secret compartment
Old Oct 9, 2009 | 03:20 PM
manolo.cabasal's Avatar
Nice 5zigen wheels, and congrats on the new S.
Old Oct 9, 2009 | 04:38 PM
takeshi's Avatar
Oh boy.
Try the Under The Hood Forum.
Old Oct 9, 2009 | 07:36 PM
Elliot6's Avatar
Congradulations, if you do spark plugs be sure you do the OEM NGK plugs. NGK makes a specific plug for just about every Asian car out there so you know you're getting the right stuff.
