Jacksonville 1st Coast S2000 Owners
Axle nut tsb tech day
Old Feb 8, 2013 | 12:37 PM
  #31
dc2-2-ap1's Avatar
Originally Posted by jimreaper
I read the wrench wasn't needed. I used the 60 degree technique.
I Have 250 torque wrench. It was clicking before the 60° mark. So I decided to go the full 60°.
The torque for the nut ends up around 400ft/lbs. The nut is torqued to 180ft/lbs, then do the 60 degree technique. My other torque wrench only goes to 150ft/lbs and you are not supposed to max out torque.
Old Feb 8, 2013 | 12:42 PM
  #32
jimreaper's Avatar
That's basically what I did.
Old Feb 10, 2013 | 06:54 AM
  #33
Redline S2K's Avatar
Give me a date and time, I have a rotating breaker bar (bought specifically for torquing axle bolts on Audis) , torque wrench and the socket needed. I can order nuts also if needed.
Sent from my SPH-D710 using Tapatalk 2
Old Feb 12, 2013 | 09:01 AM
  #34
duffsr's Avatar
Have you ordered axle nuts yet? Either way, let me know so i could get a couple and have this done as well.
Thanks for thinking of the community and setting this up
Old Feb 12, 2013 | 06:07 PM
  #35
I can get them for 3 bucks each
Old Mar 3, 2013 | 07:06 AM
  #36
Gator_S2K's Avatar
This ever happen? I'm down to join in!
Old Mar 19, 2013 | 08:43 AM
  #37
billiardboy904's Avatar
I've done this twice in the past and have some additional info for you all. Make sure to re-grease the splines and backs of the axle nuts. Using the OEM Nut is perfectly OK, no need to buy another unless you destroy the OEM somehow. I have not had any slips when working on mine and I used a 3/4 socket Breaker bar and floor jack pole extender Easy job to do.
Old May 5, 2013 | 09:00 AM
  #38
dc2-2-ap1's Avatar
This will be done at Mase's dyno day on June 8th. If you want new nuts post up. Some of the people on the prior list have already done this, so I want an updated list.
Old May 5, 2013 | 09:10 AM
  #39
That Guy 1987's Avatar
I would like to do this josh and need the nut.
Old May 7, 2013 | 04:35 AM
  #40
ao1904's Avatar
Josh, You guys are more then welcome to use my Ap1 wheels (that are on my car) as long as im back from deployment.
I'm ordering new rims anyway almost immediately after I get back.
I'm suppose to be back No later then june 5th so ill let you know if I can make it. I retorqued my Axle nuts but
not 100% sure if it was done correctly. Ill order some axle nuts.
