AP2 with J's boltons and ECU... how Much WHP?
Old May 11, 2007 | 03:34 PM
dagostino777's Avatar
Default AP2 with J's boltons and ECU... how Much WHP?
im at work right now... internet is very slow.. couple of questions.. I wanna stick to N/A.. with full J's Boltons I/H/E with stock compression...Not intrested in FI for now.. how much power will i get to the wheels with J's ecu for the AP2 with 91/94 octane.. I was told that i would need all the cooling mods.. with the heat of the header.. would it be OK with stock hood.. next question is can i run this setup without the cooling mods... would it be reliable... would a spoon headgasket be ok also... is it safe for DD? i track the car once a month... and it is my daily driver..
Old May 12, 2007 | 12:01 PM
Berner9's Avatar
Should be fine with out cooling mods and stock hood.
With full J's I/H/E and ECU you should be up at 225 whp +/- some.
Old May 13, 2007 | 03:39 AM
SilverKnight's Avatar
Why not do VAFC tuning instead of ECU?
Old May 13, 2007 | 11:09 AM
mob_blue's Avatar
and if your buying all j's parts look to spend a couple thousand
Old May 13, 2007 | 12:31 PM
i was kinda hoping to push a lil more then 230WHP. i heard that with vafc, that for some reason, the ecu will bring it back to factory settings and re-tune it... any input on that..
Old May 13, 2007 | 01:15 PM
Rashido's Avatar
i'm pushing 216 whp with my Todas without the intake...
u'll push more with a single J's titanium exhause, huge difference on high speeds..
Old May 13, 2007 | 01:34 PM
It should stay tuned
Old May 13, 2007 | 03:10 PM
I already have an J's intake and a t1r 70mm headerback single exhaust.. if i add the headers.. would i make the same power with the vafc rather then the J's Ecu
Old May 13, 2007 | 04:48 PM
GPW03's Avatar
Reset only happens on partial throttle tune. Have it tuned for WOT only and your good. Worst case, an you want both part/full throttle tuning done, reset the ecu once a week.
Old May 13, 2007 | 05:02 PM
zbrewha863's Avatar
The J's ECU is a pretty impractical piece, it doesn't even use the factory knock sensor so there is a real danger of doing damage to your car, although you're probably ok it's worth mentioning.
AP2s dyno stronger than AP1s, I'd say you would probably be somewhere around 210-215 stock, so with a 70RR and J's header you'd be at about 235whp, I don't know what kind of power their ECU makes but if it's a proper tune for your car and mods it could bump you up to at least 240whp, I would think....
