BBS LM rims with a BBK?
Old May 1, 2006 | 04:26 PM
Mr. Francesco's Avatar
Default BBS LM rims with a BBK?
So I located a shop to get me the BBS LM's that I wanted, and my question now is, can you run a BBK with the BBS LM's and no spacers?
Here are the sizes and offsets:
The fronts are 18x8 +50 and the rears are 18x9.5 +55
After dealing with my old le28 VOLKS +50 in the front, I would have had to run a 10mm spacer just to clear the spoon calipers.
Do you think the LM's would clear an Endless bbk or spoon calipers since their a mesh design?
Old May 1, 2006 | 04:32 PM
specialque's Avatar
No, I had LMs, there is no way you are getting a BBK under them on a S2000.
Old May 1, 2006 | 04:34 PM
gosixers215's Avatar
Put your wallet away Frank!
Old May 1, 2006 | 06:30 PM
haha. this is in the future months of summer...
im saving up cash this time, no credit cards.
6 month wait sucks though.
Old May 1, 2006 | 06:31 PM
what size did you have?
Old May 1, 2006 | 06:54 PM
ASMspec's Avatar
They wont work with a BBK. I would suggest staying with the smaller Brembo or Spoon calipers VS the larger ones, only because less nightmares, unless you talk with us first.
Old May 1, 2006 | 06:59 PM
Brownergy's Avatar
Even Brembos are pretty big, if anything works it will be Spoons or Wilwoods.
Good luck Frank!
Old May 2, 2006 | 04:13 AM
Ok Chris,
so how would I make spoon calipers work with 18x8 +50 BBS LM's in the front?
Old May 2, 2006 | 04:27 AM
specialque's Avatar
Guedo, I had 18x8 +50 in the front, and there is barely enough clearence for the stock brakes. I believe the magic number I calculated to run some "normal" sized BBKs (this excludes endless or stoptech) would be +37, so you would need a 13mm spacer at least.
Old May 2, 2006 | 04:28 AM
jeez, i didn't expect the stock calipers to be that close.
