Can AP1 get to 225 Dynojet RWHP
Just wondering if that is possible. I was toying with the idea of trying to get an NA AP1 to Elise power to weight ratio. I am using RWHP for power to weight and not crank because I think power at the wheels is a better measure.
From the graphs I could find, the Elise with an empty tank weighs 1984 pounds, and makes 166-168 hp stock on a dynojet. Lets call it 167. That is 11.88 pounds per hp.
Stock AP1 makes about (MY 2002-03 ecu) 190-195 (call it 192.5) dynojet HP stock at a dry weight of 2750 pounds. 14.28 pounds per hp.
I was going to add a few things to the car this year, and maybe do FI next year. I am waiting to see how people like Krafwerks and Stage One kits when they are released.
Any way if you swap these parts...
Intake -6 pounds
Berk Cat -7 pounds
Odyssey battery -14 pounds
Fujitsubo Exhaust -14 pounds
Tire and tools -32 pounds
Odds and ends -3 pounds
The car weight would be 2674 pounds. With no hp gain that would be 13.89 pounds per hp. To get to the same 11.88 you need 225.
I would also need to find another 5 pound weight loss in the car to cancel out emanage ultimate. How much does a tune weigh?
If the tune gets it to 225 you have Elise power to weight (but without Elise handling that 700 pounds lighter gets you) for about $2200.
I know a single would net more, but I hate loud fart can exhausts. I could live with a J's 60rs if it was not for the purple tip. It is the only single that I like the looks of, would gain a little over a dual, drops and extra 20 pounds over the Fujitsubo, but puple tip on a silverstone looks awful. If only they made one with a stainless tip.
I know headers lose weight but I am not convinced they do much for the money, and it would probably need to be a $1500 Mugen so I could keep stock heatshield mounting for possible Stage One SC kit.
You may ask why does equaling Lotus power to weight mean anything? Just for the heck of it. I think getting to the same pwr/wght and dropping in some gears would make for a really fun car. And then if I decide I want a scary one I can add SC.
Thought and suggestions welcome. I am bored at work today.
Intake -6 pounds
Berk Cat -7 pounds
If the tune gets it to 225 you have Elise power to weight (but without Elise handling that 700 pounds lighter gets you) for about $2200.I know a single would net more, but I hate loud fart can exhausts. I could live with a J's 60rs if it was not for the purple tip. It is the only single that I like the looks of, would gain a little over a dual, drops and extra 20 pounds over the Fujitsubo, but puple tip on a silverstone looks awful. If only they made one with a stainless tip.
With what you have listed, I would add cooling mods which will give you a more aggresive tune with the Emanage and therefore add a few more hp, yet still reliable (also drop the Berk cat and just put their test pipe in). 230 whp is not out of the ordinary with these mods.
I have to pass on the test pipe. Bunny hugger.
I have the fan switch and thermostat already. I also have a Hondata gasket but have not installed it. It looks like a full days work.
We only get 92 octane here though. I am sure that will limit the timing somewhat.
Every high HP AP1 graph I see seems to have a 70 mm single. It seems that it is much easier to reach 225 with AP2.
highest i have hit with stock exhaust is 218 whp dynojet.
that was with my custom intake, VAFC II and a testpipe,
with a real tune something like greddy ult emanage, or AEM 225 + would be easy with stock exhaust!
I would think 225 w/ an AP2 (let alone AP1) w/ just bolt ons would be tough. I have a T1R header/exhaust and TP and only pulled 216. I will do the Hondata reflash to take full advantage of these mods but that has not really increased peak power much from what I have seen. It does have a significant effect in the midrange however. Good luck and keep us up to date.
Originally Posted by Fastfour,Feb 19 2008, 05:18 PM
I would think 225 w/ an AP2 (let alone AP1) w/ just bolt ons would be tough. I have a T1R header/exhaust and TP and only pulled 211. I will do the Hondata reflash to take full advantage of these mods but that has not really increased peak power much from what I have seen. It does have a significant effect in the midrange however. Good luck and keep us up to date.
Originally Posted by Fastfour,Feb 19 2008, 09:51 PM
Is that SAE corrected on a dynojet?
