hyper rev #112/ j's racing question
Old Oct 1, 2006 | 11:03 PM
CwestinAP1's Avatar
Default hyper rev #112/ j's racing question
what is the product pictured on pg 67 bottum right corner of the hyper rev #112 issue? it is a j's racing product, but i am not exactly sure what it does. u can also see it on page 142 bottum left corner next to the lsd's.
Old Oct 2, 2006 | 12:09 AM
jonathanschley's Avatar
i don't know what any of these means. the translation is very poor. but here...
http://www.excite.co.jp/world/english/web/...p=JAEN&wb_dis=2
Old Oct 2, 2006 | 02:31 AM
Jekyoo_Style's Avatar
he's not talking about the j's racing website, he's talking about the hyper rev s2000 tuning guide.
Old Oct 2, 2006 | 02:40 AM
yeah. i know... i meant to link him to the part on the website and it says what the part is but the translation doesnt make sense.... if you go to drive train parts on the link and then the item is like the 4 one from the bottom or something.
Old Oct 2, 2006 | 04:19 AM
jdmj0's Avatar
pinion gear and ring gear something. my kanji skills lack right now, working on it.
Old Oct 6, 2006 | 01:49 AM
CwestinAP1's Avatar
anyone know? bump.
Old Oct 6, 2006 | 03:18 PM
GiFF's Avatar
It says a differential distance collar. You will need an extra shim to install this when overhauling.
Old Oct 8, 2006 | 11:43 AM
c17r15's Avatar
From J's Racing's Engrish site:
Material S45C It has specially heat-treated it.
Surface black dye processing J 'S RACING laser stamp
High-power S2000 output concentrates on the part of only small area of the pinion gear and the final gear in Defcas.
Therefore, because the change in the constructional clearance is large, the pinion gear changes, and, in the worst case, causes the result named Defbror to Distanscarar of purity with the tooth hit of the final gear though becomes the most important to give durability each clearance (backlash) at the time of the building in.
General..hardly..case..this..tooth..hit..change..o ne.
Being able to evade the danger of Defbror and extending Deforbarhorlsaicl surely become possible because it can achieve uniform tooth hit at any time if SPL Defdistanscarar is installed.
They are special parts that appeared from the super-endurance participation knowhow.
Please install it indispensably when machine type LSD and you exchange the final gears.
(attention)One Single In-line Memory Module
S2000art
Αγοραπωλησίες
Dec 28, 2012 06:34 AM
s2k DRAMA
Συμπεριφορά
May 12, 2012 05:08 AM
an_orange_s2k
Jan 29, 2011 12:40 PM
Metcalfe
Jul 20, 2007 04:54 PM
Jaydem
May 7, 2005 06:29 AM
