Inner Fender Braces...
Old Oct 23, 2006 | 05:42 PM
jonathanschley's Avatar
Default Inner Fender Braces...
like the title says.... i know what they are... but what exactly do they do? in pictures they look really thin which leads me to assume they can't be there... at least not effectively, to reduce flex in the chassis.
Old Oct 23, 2006 | 09:53 PM
Mr. Francesco's Avatar
Im not sure how to explain it, but pretty much they stiffen up the frame. Im not sure why they would work though because they bolt to the frame compared to being welded directly. For a street car, you dont need them, just get the cusco 3pc. floor bar.
Old Oct 23, 2006 | 10:27 PM
do the floor bars really make a good difference?
Old Oct 23, 2006 | 10:46 PM
AJ PwR's Avatar
The fender braces mounts in between the door inner beam to the (fender) front portion. It actually has a weld joint where Honda puts the frame together. The inner fender brace is to reinforce it to reduce flexes and improves turn in response. It's quite a noticeable difference.
The Cusco bar makes a bit difference too but IMO, it is missing a center bracket which makes the bar STRONGER plus it is way too heavy. If you want a similar type bar with better effect (lightweight), you should consider the Carbing aluminum floor bar.
Keith P
Mar 29, 2014 05:46 AM
etang789
Aug 16, 2011 11:47 PM
asdthing
Feb 27, 2010 05:42 AM
mikeyhomes
Jan 5, 2010 01:39 PM
f20c1 01s2k
Jun 25, 2008 10:07 AM
