j's header and 70rr= lean
#32
Originally Posted by thorax,Aug 7 2007, 05:17 PM
so bolt on mods will not make ur car lean enough to cause probelm?
Safe Air Fuel <14.0:1 anything higher starts melting stuff
#35
i have the 70RR, J's Header and stock intake and i was tuned by Giles as well with emanage.
i was told, i was running very lean up top too, like over 15:1
something is wrong with your car because my AP1 on giles dyno made 232whp
my current AP2 on his dyno with the above mods, made 247whp
hub dyno
hub dyno
#36
Originally Posted by ShocK,Aug 11 2007, 09:25 AM
Beats me, I've read up a lot in the NA threads and everyone says anything above 13.9:1 is unsafe. With my vafc I run about 13.8 throughout the rpm range.
my car is tuned at like 12.5:1 and it made almost 250whp
#37
hub dyno
hub dyno
How are you liking your tune? The NA tune by Giles was pretty fun
#39
Originally Posted by iDomN8U,Oct 21 2008, 02:44 PM
This is concerning, since there are tons of people running I/H/E without any tuning.
More input would be appreicated!
There have been some cases of blown engines (spark plugs melting and destroying the cylinder alls and pistons) due to a prolonged lean condition. How many of the blown engines out there are due to a lean condition? Hard to say.
Also, most people that they their car is fine probably do not conduct regular compressions tests to see what is going on. Even FI guys will not notice a loss of power but see the true results from a compression test and evidence of internal damage.
Bottom line is, why risk it?
#40
the header is generally the biggest culpurate to running lean.
if you install anything other than an intake and exhaust your afr is going to start getting out of line. how much is up for debate and dependant on your combo of parts, but it is something to be aware of.
i had my setup tuned with an emu. all bolt ons exect a header, tuned to 12.9 /13.1 perfect ratio for n/a. after installing my rick's header i went for a re-tune...afr jumped up to 14.5ish. not good.
