J'S catch tank install help
Old Jul 10, 2005 | 01:58 PM
MidnightDragon's Avatar
Default J'S catch tank install help
Well just installed my J'S catch tank and car seems to ocasionally bog down and does not seem as responsive when stepping on the gas from low RPM or even sometimes when i let of the throttle.
This is how I installed it
1. Remove hose from 1st slot on valve cover that leads to the Comptech intake.
I then used 1 of the plugs that came with the catch can to plug the hole in the intake and ran the hose that came with the catch tank to the 1st slot in the valve cover to the can.
2. Then removed the hose from the 2nd slot on valve cover that connects to the 1st slot on the intake manifold. I plugged that 1st slot on the intake manifold and ran the 2nd hose from the 2nd slot on the valve cover to the can.
I do have 1 plug left not sure if that's an extra or do i have to plug something else. Any help would be helpful.
Old Jul 10, 2005 | 02:06 PM
spider2k's Avatar
Active Streak: 30 Days
shouldnt it just be in line with one or the other?
from valve cover ---> to catch can ---> back to the intake or manifold depending on which one you unplugged.
Old Jul 12, 2005 | 08:23 PM
With all the JDM enthusiasts on this site somebody has to have or installed a J's Catch can.
Old Jul 12, 2005 | 08:48 PM
BlueS2000Boy's Avatar
ya thats sounds pretty right....
Old Jul 12, 2005 | 08:54 PM
moparacker's Avatar
It should look like Slow's setup in this thread (5th post): https://www.s2ki.com/forums/index.php?showtopic=270320
The way you have it setup you're not relieving any pressure from the crankcase, hense the reduced performance.
Old Jul 12, 2005 | 09:06 PM
Yep thanks noticed that also the way Tenblade has it I have the same intake.
I think the problem might be i don't have the hose from the 1st slot on the valve cover(Noticed red Hose) going onto the intake anymore and i plugged that hole in the intake up. I went for a cruise tonight and whenever i let of the gas i would here alot of resonance in the intake and the car would start bucking agian like the other night.
Old Jul 12, 2005 | 10:13 PM
ASMspec's Avatar
Yeah some of us have had it for years. Just to lazy to post. Sorry. Pm me or you should have enough with those posts. Try a search also. I believe we posted a how too back in 2002 or 2003. Cant remember.
Old Jul 12, 2005 | 10:29 PM
Gonna try to set it up today the same way Tenblade and Slow have it. Hope this solves my problem.
Old Jul 14, 2005 | 08:13 AM
Xplosiv's Avatar
if u cant install the catch tank, your so not a DIY person. Maybe take it to a shop and let them do it.
Old Jul 16, 2005 | 05:46 PM
BlueIon's Avatar
wow, give the guy a break, i would be asking question also if was unsure about something, thats what this forum is for. If you cant help, then dont post.
