J's racing specialist
Old Aug 30, 2008 | 08:53 AM
David_T's Avatar
Default J's racing specialist
Just wanted to know if these items would fit onto my car before i go with the go ahead. My car is a 07 with the j's racing kit. Engine wise its stock. So if you guys could help me out witha YES or NO beside each item that would be great
Thanks
Here the items:
J's Racing Engine Torque Damper & Strut Bar
J's Racing Strut Bar (Rear)
J's Racing High Pressure Radiator Cap
J's Racing Low Tempurature Fan switch
J's Racing thermoswtich
J's Racing SPL thermostat
J's Racing SPL Engine Magnetic Drain Bolt
Js Racing Oil Cap
J's Racing Carbon Cooling Plate
J's Racing SPL Valve Cover
J's Racing Type-S Carbon Air Duct for Stock Air Box
J's Racing Tsuchinoko Intake
J's Racing Titanium Shift knob - Ti Blue
J's Racing Rear Lower X-Beam Bar
Js Racing S2000 SPL Exhaust Manifold
Spoon Diffuser
Spoon Sports Front Cross Beam Bar
Spoon Sports Rear Cross Beam Bar
Cusco Floor Bar/Chassis Reinforcement
Old Aug 30, 2008 | 09:04 AM
57udl3y's Avatar
i'm not an expert, but if you get j's type-s carbon air duct for stock air box there is no need to get j's racing tsuchinoko intake, unless your just asking on all products. but i would have to assume they would all still fit. so
J's Racing Engine Torque Damper & Strut Bar -yes but get LHD version otherwise you'll hate it
J's Racing Strut Bar (Rear) - should but i hear its pointless
J's Racing High Pressure Radiator Cap - yes
J's Racing Low Tempurature Fan switch - yes
J's Racing thermoswtich - yes
J's Racing SPL thermostat - yes
J's Racing SPL Engine Magnetic Drain Bolt - yes
Js Racing Oil Cap - yes
J's Racing Carbon Cooling Plate - yes
J's Racing SPL Valve Cover - yes
J's Racing Type-S Carbon Air Duct for Stock Air Box - yes but get either or
J's Racing Tsuchinoko Intake - yes but get either or
J's Racing Titanium Shift knob - Ti Blue - yes
J's Racing Rear Lower X-Beam Bar - yes but may get in the way of the spoon/cusco not sure though
Js Racing S2000 SPL Exhaust Manifold - don't think so only up to MY03
Spoon Diffuser - not sure thought it was made to be used with their S-Tai rear bumper but may be wrong
Spoon Sports Front Cross Beam Bar - should but may get in the way
Spoon Sports Rear Cross Beam Bar - should but may get in the way
Cusco Floor Bar/Chassis Reinforcement - should but may get in the way
*keep in mind i havn't owned these parts or tried just basing on what i've read and remember so wait for more responses or do more research.
Old Aug 30, 2008 | 09:30 AM
JimiChanga's Avatar
Okay, you don't need a carbon air duct if you're getting the tsuchinoko intake. The tsuchinoko intake is a full replacement for the stock airbox, and since you have the j's racing kit, make sure you get the tsuchinoko intake for the type-s bumper. J's racing rear lower beam will conflict with spoor rear cross beam bar, so choose which one you want. Oh and the intake will need a slight modification to fit. I forget why. It has to do with a slight difference in the 06+. Other than that, you're good to go.
Old Aug 30, 2008 | 11:52 AM
innovation's Avatar
Thanks
Here the items:
Js Racing Oil Cap
Spoon Diffuser
J's Racing Engine Torque Damper & Strut Bar YES
J's Racing Strut Bar (Rear) YES BUT THE STOCK IS FINE
J's Racing High Pressure Radiator Cap YES
J's Racing Low Tempurature Fan switch YES
J's Racing SPL thermostat YES
J's Racing SPL Engine Magnetic Drain BoltYES
Js Racing Oil Cap YES
J's Racing Carbon Cooling PlateYES
J's Racing SPL Valve Cover YES
J's Racing Tsuchinoko Intake YES BUT NEEDS MODIFICATION
J's Racing Titanium Shift knob - Ti BlueYES
J's Racing Rear Lower X-Beam Bar NEVER HEARD OF THIS FOR REAR
Js Racing S2000 SPL Exhaust Manifold YES
Spoon Diffuser NOT SURE FOR AP2 REAR BUMPER
Old Aug 30, 2008 | 04:16 PM
David_T's Avatar
No no i understand that there is 2 different intake system listed.. im just asking if either or will fit
and thanks for the info
david
Old Aug 30, 2008 | 04:20 PM
zbrewha863's Avatar
I would check on the valve cover, I think it's different for 06+, I don't know if that will fit
Old Aug 30, 2008 | 11:02 PM
fenixv8's Avatar
everything will fit except the J's Racing Low Tempurature Fan switch,
J's Racing thermoswtich, J's Racing SPL thermostat. Also the intake will need modification, you can stop by my house and i can show you the intake. and the other things on my car.
Old Aug 31, 2008 | 09:23 AM
HvRRZ's Avatar
thermos will fit, and everything. the only thing that won't is the fan switch
Old Sep 3, 2008 | 01:07 PM
David_T's Avatar
I was wondering if anyone here knows if someone here has a j's racing exhaust on there s2k that is 06+.....I've been reading different answer..if someone can please clear this up for me that would be great
thanks
dave
Si@Hendy Performance
UK & Ireland Traders Forum
16
May 7, 2012 08:16 AM
Paris-Xania
Κινητήρας - Μετάδοση - Περιφερειακά
Oct 11, 2011 06:19 AM
