JDM AP1 Pistons in an AP2? CR change?
Old Apr 2, 2008 | 07:28 AM
  #21
LostMotion's Avatar
I don't think there is a calculation because it's based on a lot of factors. For example 12.5 would be fine if you pulled enough timing.
Old Apr 2, 2008 | 12:20 PM
  #22
ShocK's Avatar
Originally Posted by BlownAP,Apr 1 2008, 04:15 PM
you are quoting shawn church, LOL.......
shawn needs to ditch those dynapacks and get a superflow, talk about superior tuning devices.
lol, depends on what accurate means I guess. If your talking real world hp numbers then no. just look at some of the dyno's from a dynapack, its more like crank hp than anything. If your talking tunability and accuracy between runs, etc then yes. Superflows are crap too, so are dynojets.
Old Apr 2, 2008 | 12:34 PM
  #23
BlownAP's Avatar
[QUOTE=ShocK,Apr 2 2008, 01:20 PM] lol, depends on what accurate means I guess.
Old Apr 5, 2008 | 10:11 AM
  #24
toofast4yalll's Avatar
12.5:1 is fine on 93 octane, as long as the tuner knows what he's doing.
Old Apr 5, 2008 | 06:44 PM
  #25
Urge's Avatar
Sponsor
Originally Posted by Fyrestrike,Apr 1 2008, 05:59 AM
Great link... Does he still post around here?
__________________
Old Apr 6, 2008 | 12:36 PM
  #26
LostMotion's Avatar
http://www.j-garage.com/form.htm
They are a little over $150 each. There are three pistons based on slight bore differences. If you have a relatively new motor I think it would be safe to look at your pistons through the spark plug hole and just copy what you have already. If your motor is pretty worn though I don't know if that is the best thing to do, you may need to actually measure.
I'm going to do this mod.
Old Apr 7, 2008 | 08:33 AM
  #27
Asura's Avatar
Toda spec C's only made 8WHP with cam gears and 109 octane.
The JDM ap1 pistons will get you to 12.65:1.
Old Apr 7, 2008 | 04:48 PM
  #28
LostMotion's Avatar
What shop would you use in SoCal to replace pistons?
Old Apr 9, 2008 | 06:54 PM
  #29
BlownAP's Avatar
It is going to be an arm and a leg, basically overhauling the whole engine........ save it for more engine, stroke it while you are in there.
Old Apr 9, 2008 | 07:42 PM
  #30
LostMotion's Avatar
I was budgeting around $1000, maybe more?
