jdm f20c...
Old Nov 16, 2006 | 02:43 PM
i</3speedbumps.'s Avatar
Default jdm f20c...
so is it smoggable... some say it is.. some say it isnt.
Old Nov 16, 2006 | 03:12 PM
deathsled's Avatar
I dont see why not, as I assume you would be swapping the smog control equipment on to the replacement
Old Nov 16, 2006 | 03:14 PM
zbrewha863's Avatar
That's a tough question, and I don't have an answer for it (since I don't live in CA) but my thought is that it would all depend on what kind of ECU you used to run the engine -- on a JDM F20C you would be running the JDM ECU, which I do not think is legal in CA ... my best guess is that you would have to run a US ECU on it to pass smog, in which case you would effectively nullify any benefits of the JDM F20C.
Old Nov 16, 2006 | 05:03 PM
im most likely gonna run the usdm ecu since ive heard that both the jdm motor and usdm motors make the small hp/tq
Old Nov 16, 2006 | 05:11 PM
Johnny Sack's Avatar
the only reason for this is due to the fact that japan gets higher octane and thus the ecu's are tuned a hair bit more aggresively. on our octane you wont be making anymore power then a UDSM F20. the compression difference (.5:1) is going to be cancelled out by the knock sensor, which when it sees the 91 octane and will pull timing and make you possibly slower than a stock US F20. its not worth the money and time, just tune your USDM motor.
Old Nov 16, 2006 | 06:22 PM
im not buyin the jdm motor for more hp/tq. i need a motor and the jdm motor is the cheapest way for me to go.
Old Nov 16, 2006 | 06:23 PM
Old Nov 16, 2006 | 07:33 PM
GrandMasterKhan's Avatar
if he is in Fl wouldnt he have access to 93?
Old Nov 16, 2006 | 08:13 PM
he might, i get 93 here in seattle, but japan gets the equvilant of 108 octane.
Old Nov 16, 2006 | 08:16 PM
u guys are lucky with your 93 octane!
