JDM Gauge '04 cluster
Old May 26, 2005 | 06:30 PM
APEXSEAL's Avatar
Default JDM Gauge '04 cluster
Need to know where I can find a '04 JDM gauge cluster (9k redline), preferably used. In case you're wondering, I am going to experiment with a 00-03" ECU.
Thanks
Old May 27, 2005 | 03:38 AM
APEXSEAL's Avatar
Wow, 31 views and not a clue!!??
Old May 27, 2005 | 09:45 AM
ASMspec's Avatar
Probably because its a waste of money??? No problem with your factory cluster? No need to experiment. Why fix something thats not broken? BTW it looks the same as an USDM 00-03 cluster anyway. Remember they dont have the 2.2L motor new AP2 stuff.
Old May 27, 2005 | 10:05 AM
CrazyPhuD's Avatar
actually it is different.....
However it's not clear that it will read in MPH...you'll notice no MPH/KPH button....you may need to find a UK MY04 cluster.....
Old May 27, 2005 | 10:12 AM
CrazyPhuD's Avatar
Yep the UK version has the MPH/KPH selector button, unless you want to be mad JDM YO! and drive around in KPH all the time
Old May 27, 2005 | 10:18 AM
ASMspec's Avatar
Interesting I was wrong. I apologize to the doctor.
But it looks the same as the OEM 04-05 dash which we all know will work with on the existing 00-03 cars.
Old May 27, 2005 | 10:25 AM
FIZZ-AP1's Avatar
yeah, it looks the same, but with the 9K redline...ours has the 8K redline. he has an '04 and is gonna experiment with an AP1 ECU which had the 9K limit...hope you understand, it's kinda confusing
Old May 27, 2005 | 10:28 AM
CrazyPhuD's Avatar
Oh yea...the MY04 dash will work I think he just wants to be able to see it rev ot 9K to know when to shift, instead of having the standard MY04 cluster flash at 8K with the MY00-03 ECU. Too bad the gauge clusters are pretty expensive...new will probably run over $500 easy.
Old May 27, 2005 | 11:05 AM
Mr. Francesco's Avatar
so AP1 and AP2 clusters are interchangable as long as you have the ECU?
ex:
an AP2 cluster will work with an AP1 ecu? No problem at all, its just a bolt up and plug in and your good to go?
Old May 27, 2005 | 11:11 AM
Chadwick's Avatar
ex:
