Modulo suspension
Old Apr 5, 2006 | 12:57 PM
truths2k05's Avatar
Default Modulo suspension
Likes?, Dislikes? and where it was acquired.
Old Apr 5, 2006 | 02:54 PM
Harpoon's Avatar
Those who have them seem to like them. The number is very small though due to the fact that you have to import directly from Japan. The set does drop the car 10mm and you can't go higher or lower than that. The fronts have 5 different degrees of adjustable firmness.
You can get them here: www.japanparts.com
The cost isn't too bad but you have to pay a couple of hundred bucks in shipping/import cost.
Old Apr 5, 2006 | 06:17 PM
zbrewha863's Avatar
yeah, you realize that 10mm is barely any drop at all, right? I heard that the Spoons are basically just more agressive, more adjustable, better performing versions of the same coilovers for a little bit more money, just my 2 cents
Old Apr 5, 2006 | 09:35 PM
AJ PwR's Avatar
For that price, you probably can end up with a set of coil-over which will work better than that.
Old Apr 6, 2006 | 05:06 PM
truths2k05's Avatar
For the price of the spoons I can get the modulo and a J's 60 rs exhaust. I will probably end up with the modulo after all.
Old Apr 6, 2006 | 06:30 PM
Harpoon's Avatar
Post a follow up when you do. They're rare.
Old Apr 7, 2006 | 12:37 AM
zbrewha863's Avatar
What are you looking for in a coilover suspension? This is basically a *slightly* modified version of the stock coilovers -- that retails for US$1330. For that price you could get a Tein Type Flex system. But if you're looking to just have a rare coilover system that basically rides like stock, handles like stock, and has very little adjustment, then by all means go for it.
Old Apr 7, 2006 | 04:46 AM
truths2k05's Avatar
Tein are great. And showa makes great products as well. Why would mugen and spoon use them then? The modulo suspension wouldn't upset the cars balance and that is precisely what I''m after. Different strokes for different folks. I have a certain way that I like to modify my cars.
Old Apr 7, 2006 | 12:19 PM
zbrewha863's Avatar
Well it sounds like you already have your mind made up then -- good luck!
ScienceofSpeed
15
May 15, 2013 03:54 PM
Fatbloke
Jun 14, 2009 02:57 AM
shakes
Dec 13, 2008 11:46 PM
A7DY W
Nov 1, 2007 01:35 PM
