revving to 10k?
Old Oct 11, 2007 | 08:13 AM
Tjs S2k's Avatar
Default revving to 10k?
i know it wouldnt be practical, nor make good power up that high, but when i see all motor civics and such rev up that high, i was just wondering if anyone in there S has a setup to rev higher?
Old Oct 11, 2007 | 09:31 AM
s2kennmark's Avatar
my AEM is set to 9500rpm cut. you can do that with standalone, stock engine is rated to rev at 11k and i think can handle 12k... but like you said, what's the point? no power there anyway.
Old Oct 11, 2007 | 10:01 AM
Soul Coughing's Avatar
so what about all the s2k with cracked intake retainers from over-revs? at what RPM do the exhaust valves start to float and hit the pistons? wasn't the guy on here that was doing 11-12K revs lose his motor?
Old Oct 11, 2007 | 10:53 AM
GinoGT's Avatar
11k or 12k sounds pretty extreme. *Maybe* the bottom end could handle it, but the valvetrain sure isn't, especially AP1 retainers.
Old Oct 11, 2007 | 10:54 AM
modMonkey's Avatar
haha, yeah. Except it was an accident.
Old Oct 11, 2007 | 02:36 PM
FF2Skip's Avatar
I had my rev limiter set to 10k when I was sc'd. I had the valvetrain lightened though. Currently my stroker is set to about 9400-9500rpm although I usually shift at 8500.
And on a road course, there are times when a few extra rpms does benefit you despite not making more power.
Old Oct 11, 2007 | 06:55 PM
LostMotion's Avatar
You can easily rev an AP1 to 10k but the expected life of your motor is going to be substantially lower.
The problem with revving AP2s past 8500 is sleeve wear and unfortunetly this happens pretty quickly.
Old Oct 11, 2007 | 07:19 PM
FF2Skip's Avatar
No, you can't... not until you lighten the valvetrain. And after lightening the valvetrain, could you be more specific when you say the engine's life would be substantially shortened? I'm curious. Let's assume a non-boosted, stock compression scenario.
Old Oct 12, 2007 | 11:15 AM
INTJ's Avatar
I thought the sleeves were the same metalurgy?
Old Oct 12, 2007 | 11:19 AM
MINES13's Avatar
The piston speeds at 9+K on a 2.2 are too much for the stock cylinder bores. I rev my stock bottom end 2.2 to 9K, This is considered safe once you have upgraded your valve train. No reason to rev your engine much passed peak power though.
