Risk of running too lean?
Old Jan 26, 2007 | 10:49 AM
FurY's Avatar
Default Risk of running too lean?
Hey all, I currently have the J's tsuchinoko intake, j's 60rs dual exhaust, and a test pipe. I'm considering purchasing the J's header as well but I've read that by running all of these mods together you run leaner than before. I was wondering if this could hurt the engine and also if I will be losing power by putting the header on in addition to the mods I already have. I'm not interested in using a VAFC or other fuel management at this point to rich the fuel out accordingly.
Bottom line, would it be a problem if I add a J's header to my current setup and would I notice any gains? Thanks in advance!
Old Jan 26, 2007 | 11:02 AM
BlownAP's Avatar
you will be lean, but not lean enough to cause any damage....
Old Jan 26, 2007 | 11:43 AM
Tolgahan Ures's Avatar
^ I agree. J's header can give you some power with your setup.
Old Jan 27, 2007 | 03:05 AM
CoralDoc's Avatar
Once you add all your mods, why not go to the dyno (one with an A/F sensor) and find out for yourself if you're running lean? I'd do that for my own peace of mind.
Old Jan 29, 2007 | 04:54 PM
blackout's Avatar
seems to me that the ECU would adjust some for that too. The S2 runs so rich it "shouldn't" be a problem
Old Feb 6, 2007 | 11:01 AM
K2Rhiro255's Avatar
I don't see any reason this set up will cause any damage. aren't you running OEM ECU?
Old Feb 6, 2007 | 10:15 PM
zbrewha863's Avatar
The older AP1s run rich, the newer ones do not run very rich at all. I agree with the others, I would put it on a dyno and check it, not only will it be the safe way to go, but you'll also know exactly where your powerband is and how much power you're making (relatively).
Old Feb 8, 2007 | 07:27 AM
FurY's Avatar
I'm on the OEM ecu and I had heard that the AP2 ecu's aren't as rich as the AP1's which is why I was curious if I would start running to lean.
Old Feb 9, 2007 | 05:49 PM
TitusS2k's Avatar
Get a tune with nice management, and PLX-300 wideband or AEM. Thats the best bang for the buck, Your not getting the full use out of mods untill you tune for those mods!
06s2kid
Jul 31, 2017 08:36 AM
pawel1026
Jun 9, 2014 06:40 AM
David_T
Jan 6, 2009 12:30 AM
00SpaYellow
Oct 31, 2008 11:16 PM
dthondatune
Oct 3, 2006 01:18 PM
