Spoon ECU
Actually JDM tuner ECUs have bypassed/disabled on all sensors, some very dangerous ones ala the Knock Sensor. The ratio goes Amuse > Mine's VX-ROM > J's Racing > Mugen > Spoon. Note that the usual big players are at the end because they started the very first release and all the base work for the rest. With a max power net of 20 ~ 10wbhp with I/H/E complimenting mods.
Infact they didnt believe me that it wasnt the stock one because of this as they believed that the ECU would come back with very little.
Either way its a great upgrade
Originally Posted by Lickermat,Aug 24 2006, 11:42 PM
This may be true and Im no expert but when my car was in for its serivce I had the guys plug in my ECU and they could see every readout /sensor as per the OEM ECU , hence my comments.
Nope mine runs sweet, no issues I asked my dealer to plug in to look to make sure that it was all ok.
There is no reason why it should cause any issues; you do need to reset the ECU once fitted as with any ECU replacement.
Hmm thats odd, my friend that sold it to me had a check engine light and i got it after about 2 minutes after install. I figure the ecu was automatically reset since it was unplugged.
No idea Y , there are a few of us in the UK with the ECU with no problems. Once you plug in the ECU then reset it so that it clears the learning. On first boot the car will idle high once reset it will all run as normal. Im no enginner but the engine light may be somthing else
Matt,
Most of these type of ECU's retain all of the OEM parts / chips etc - so very little is changed apart from the fuelling / timing parts of the map. So all your OBDII functions are untouched. Its just easier for them to sell you a whole ECU, rather than risk the reputation / liability issues of letting you replace a chip inside the ECU itself. (hence the exchange basis on most of them)
For this reason it will appear to a diagnostic tool / monitor as a stock ECU - because essentially it is.
Mugen does not utilise the OEM knock sensor - risky IMO.
MB
MB
Immobilizer disabled does not activate a CEL ... And MB's comments on why they still produce read out is accurate. While disabled sensors are only applicable for true racing use, using such an ECU for any other application otherwise designed is a hazard for the returned performance increase.
