Street Clutch
Old Dec 10, 2006 | 07:59 AM
S2kracka's Avatar
Competition Stage 2 clutch and 11 pound flywheel (if you want a lighter flywheel).
Old Dec 11, 2006 | 08:34 PM
Spookee's Avatar
i was actually looking into a clutch as well and i decide to go wit ATS, fully streetable with da capability of running on the track as well kit includes flywheel, pressure plate and disc, but it's a bit on the pricy side but hey only the best for an S2K ryte...lol
Old Dec 11, 2006 | 08:58 PM
David-D's Avatar
yeah dats ryte mang!!!
Old Dec 11, 2006 | 10:28 PM
smirfs2k05's Avatar
Around what price range are you guys paying to have clutch installed?
Im taking my car in soon to have my trans looked at for the tsb 1st gear pop 2nd gear grind and hard to get into reverse haha i gots me a bad trans so im hoping they'll be nice enough to install my clutch for me most likely will be ACT Street/Strip
Old Dec 12, 2006 | 07:48 AM
ShocK's Avatar
sounds like a bent shift fork
Old Dec 12, 2006 | 08:16 AM
ShocK's Avatar
Originally Posted by neveronlines2k,Dec 7 2006, 08:22 AM
Toda Flywheel, with Excedy clutch. Betterbite than stock and peddle pressure is just slightly stiffer than stock and it will rev quicker too.
exedy makes clutch plates for ACT, I was looking at mine just now and it says it on the disc. I guess ACT makes the PP.
Old Dec 15, 2006 | 03:20 AM
Antonov's Avatar
why are you getting a new clutch? is your oem going out? just wondering. Get a light flywheel, so much better for rev matching heel/toe. Does SPEC make a clutch for the s2k? I know they are really good for euros
Old Dec 15, 2006 | 07:48 AM
Jsmply's Avatar
They probably will, I had it done that way. Lots of other members have too. You just need to have a cooler dealer and service guy/mechanic.
If you are an AP2 you definitely want to change the flywheel. If you reserach it and read Billman's threads, you will see what I am talking about. His theory is due to the heavier flywheel (compared the ap1's) the ap2 CANNOT be shifted as fast as an ap1 without an aftermarket lighter flywheel. The flywheel cannot slow down fast enough and you can still get some slippage even with the CDV removed.
Just an FYI, I had the hardtopguy kit installed (ACT pressure plate, stock disc) except that I went with the Toda flywheel since the Comptecth was not available . . . and I'm very happy with it.
Old Dec 15, 2006 | 12:58 PM
deathsled's Avatar
I think that applies only if you keep the factory pressure plate. The problem isnt the flywheel, just with the holding capacity of the pressure plate. If you upgraded the pressure plate and kept the flywheel the same I'm sure you could shift just as fast, probably chirp tires easier during shifts due to the stored energy of the heavier flywheel
Old Dec 18, 2006 | 09:55 AM
METATRON's Avatar
SPEC does make a clutch for the S2000
