Stroker kits
Old Dec 11, 2007 | 09:02 AM
yosephs2k's Avatar
Default Stroker kits
I'm thinking about getting a stroker kit and i would just like to know if there are any other supporting mods i need? does it depend on displacement?
can i just use a greddy emanage ultimate or apexi Vafc to tune it? or do i need a full stand alone?
thanks in advance
Old Dec 11, 2007 | 10:08 AM
Mr. Francesco's Avatar
I think you can make the Greddy work right with it.
Old Dec 12, 2007 | 08:51 AM
medicalstudent's Avatar
AEM EMS and lots of money.
Old Dec 12, 2007 | 09:40 AM
HvRRZ's Avatar
around 10K plus other expenses depending on what other parts you want to modify just in case.
been doing a lot of research myself on this for my project.
Old Dec 12, 2007 | 01:06 PM
yosephs2k's Avatar
i want to keep it simple. just a stroker kit and a 70mm exhaust, i/h.
would a greddy emanage ultimate do the job?
do i have to change fuel octane too?
Old Dec 12, 2007 | 01:17 PM
HvRRZ's Avatar
Not sure if the emanage would work, but it's possible. here's what I have gathered so far:
stroker kit
aem ems
fuel pump
larger injectors
head work
plus other mods(clutch, cooling, etc)
and labor!
these alone will set you back about 8-10K
the octane depends on how high you go with the compression on the kit. higher the compression, the better to have higher octane.,
Old Dec 12, 2007 | 06:07 PM
kial007's Avatar
You might want to talk to the tuner you plan to use or someone experienced w/ Emanage. And the total price really depends on the kit you purchase, supporting mods, and how much work you do yourself. Here's a link to my build.
https://www.s2ki.com/forums/index.php?showtopic=538548
Old Dec 12, 2007 | 06:27 PM
yosephs2k's Avatar
stroker kit
aem ems
fuel pump
larger injectors
head work
and labor!
this may be a stupid question but do i need head work with a stroker kit?
is every mod u listed necessary?
i thought abt aem ems but with the available harness the cel will stay on.
r u planning on swapping to return fuel system?
Old Dec 12, 2007 | 07:53 PM
HvRRZ's Avatar
everything aside from "plus other mods" is necessary. I only mention then because it may be a good idea to upgrade them during the process for peace of mind. For me I don't want to have to deal with failed parts later down the line.
head work is not necessary, but a good idea to atleast get springs, and valves.
I'm still figuring things out about this type of upgrade. Since I have an 07 want to make sure I don't run into trouble. However I don't think converting the car to a return fuel system will be necessary. By biggest concern is tuning, and I am waiting for some one to come out with a stand alone ecu that will work with my year.
Old Dec 12, 2007 | 08:21 PM
yosephs2k's Avatar
thank u for the info
There is a harness for the greddy emanage ultimate to work with 06+ cars. and a harness from autowave? for the aem ems but u will get a cel with no ways of removing it.
