VAFC2
Old Aug 31, 2006 | 09:43 PM
s2krazy01's Avatar
Default VAFC2
Don't have one yet but is the VAFC2 a DIY mod or should an inexperienced tuner get a professional to adjust fuel curves? What are the potential consequences of improper tuning? How much time could one expect to shave off the 1/4 with this mod alone?
Old Sep 1, 2006 | 03:40 PM
negcamber's Avatar
Installation can be DIY (especially with a pre-built Frog or Boomslang harness). It can be tough to get all the wires to fit back behind the kick panel however (for you or a pro).
Tuning should be left to experienced tuners with the right equipment (wide band).
Improper tuning can lead to a burned valve ($$$) if you go too lean (and you won't know if too lean unless you have a wide band).
Prob save 0.1 or 0.2 seconds...maybe. Expect 8-10hp peak but larger gains across the entire power curve.
Old Sep 1, 2006 | 07:50 PM
s2krazy01's Avatar
Thanks for your input negcamber!
Just a follow-up dumb question. How is it possible to see only 10hp peak but more throughout the powerband? One post said something about gaining 30tq before vtec? Maybe I misunderstood...
Old Sep 1, 2006 | 08:10 PM
silentdancer's Avatar
do not tune it yourself, each car is different so you cant just copy someone's settings. i gained 10whp on a dynojet just from vafc2. i gained a lot though before vtec. hp and tq
Old Sep 2, 2006 | 06:49 AM
negcamber's Avatar
Visualize a dyno power curve represented by holding a plastic ruler at each end...now bend the ruler up. The end points are still the same, but along the curve you now have points that are higher than before.
The reason this happens is the fuel mapping of the oem ecu...at some points on the rpm curve it runs more richly than it needs to. By leaning the car out at those points you will see more dramatic gains.
One other method tuners use is to lower VTEC engagement...this dramatically smooths the power curve and show significant increases of both hp & tq in the 5000-6000 rpm range.
Old Sep 2, 2006 | 11:00 AM
s2krazy01's Avatar
I think I understand now. So when people say "peak" power gained, they mean the highest point on the dyno curve (basically redline), not necessarily the biggest gain overall. Unlike advertising for i/e systems, which promote the largest gain at any point in the powerband. Thanks again guys!
Old Sep 5, 2006 | 06:01 AM
ShocK's Avatar
boomslang harness for installation ease. -5% correction after 6k for a good base map. U'll notice a difference and still be running safe A/F ratio.
Old Sep 9, 2006 | 05:21 PM
Dino Antonov's Avatar
Banned
can you still pass smog with the vafc2?
Old Sep 10, 2006 | 05:11 PM
ShocK's Avatar
I would think so with the S running as rich as it does stock. Cuz u'll be leaning it out it should pass. just a guess.
Old Sep 10, 2006 | 08:36 PM
Banned
id think so too. i dont think it would fail under visual right.
liquid_helix136
45
Mar 30, 2009 11:55 AM
s2000Junky
16
Feb 10, 2009 06:15 PM
shivers
Jun 27, 2005 12:36 PM
elude
Dec 24, 2004 11:32 PM
