Velocity Stack
Old Aug 2, 2007 | 01:18 PM
Project22a's Avatar
Default Velocity Stack
Taken from the ITB thread
Originally Posted by MINES13
Let it breathe: Open intake path. ITBs or a proper common plenum will do wonders. The more restrictions you can eliminate before the intake ports the better. Don't get sucked into fancy intake setups. Spend your money on either the biggest throttle body you can fit or increaes your plenum volume. Rule of thumb on plenums is you either make your plenum large and your TB small, or visa versa. Bigger is not always better. Anything before the TB is just a restriction. Velocity stack on the factory TB will KILL any cheese dick intake you are gonna buy from JDM land.
Has anyone actually tried this? Hondata IMG + Larger Bore TB + Velocity Stack? What kind of tuning/EMS would be required for this? How safe would this be without tuning? What about heatsoak? Am I smoking crack?
Old Aug 2, 2007 | 02:55 PM
BlownAP's Avatar
Try it, I run a velocity stack on the end of my custom intake. but I have not tested what the effects of just the VS are.
I think if someone is going to go out and say the VS is better than XX intake, they had better have proof......
Old Aug 2, 2007 | 05:39 PM
Project22a's Avatar
Is yours similar to the PRM?
Old Aug 2, 2007 | 05:49 PM
BlownAP's Avatar
I am actually using the PRM filter and velocity stack..... the Stack is very very cheap and flimsy...... I am working on getting a nice polished on or having the one i have painted
Old Aug 2, 2007 | 08:38 PM
GrandMasterKhan's Avatar
so then an open throttle body with a Velocity stack and NO filter would make the most power vs any possible intake setup?
Old Aug 2, 2007 | 08:44 PM
BlownAP's Avatar
says one person, no dyno sheets or evidence to back it up. I dyno'd my car once with nothing, just the Throttle body. no intake or Velocity stack, and the car made like -13 WHP vs having the stock intake....... I can not see a VS making that big of impact.....
Old Aug 3, 2007 | 04:04 PM
vader1's Avatar
In a couple of the older threads Ultimate Lurker was commenting on how with header and exhaust modifications he found the F20c to be "starving for air". He commented on the TB and plenum both to be too small.
I don't know enough to comment on whether one should be small and one large, I thought you want to eliminate any restriction.
I have also searched a jillion bolt on threads and I found one curious. I can not remember the thread, but one guy was posting dyno plots on his car from a dynojet with your average I/H/E mods and was consistantly several horsepower more than most people. (I know, I know, different dynos, different conditions) but the one extra thing he had was a spoon TB. I am sure any bored TB would do. But it makes me wonder if a bored TB would make that much difference on an NA car.
Msst FI guys say it won't but that old thread and UL seemed to give reason to think otherwise. Is he still posting on the board?
If ITB's can make power over stock by letting in more air, I don't know why changing TB and intake manifold could yield results somehow.
Anywho.....too bad there are no alternatives for intake manifolds to choose from. Only that carbon fiber one that looks kind of nasty.
Old Aug 3, 2007 | 06:25 PM
75911's Avatar
http://www.full-race.com/catalog/product_i...f936e27493abfa5
Old Aug 3, 2007 | 08:03 PM
Project22a's Avatar
IIRC that thing has some kind of issue clearing the hood?
Old Aug 3, 2007 | 08:50 PM
75911's Avatar
https://www.s2ki.com/forums/index.php?showt...80&hl=hypertune
