clicking noise
sup everyone
I wanted to know if anyone hear is experiencing or has experienced a clicking noise in there s2k. I only hear it when i'm beginning to accelerate from and stop or
going in reverse, only hear when car just starts to go. axles maybe?? my car is just under 50k anything i need to be aware off? noise is for sure coming from the rear.
thanks,
Bobby
thanks,
Bobby
Originally Posted by SWIFT2000,Mar 13 2006, 10:52 AM
sup everyone
thanks,
Bobby
thanks,
Bobby
KP
Well, I've had it... still have it... and that's at 130K+ miles now. I've retorqued the fart out of the axle nuts, replaced the axle nuts, and even swapped the outer CV joints from left to right so far.
At this point, I'm actually considering my rear brake disc rotors. Mine are aftermarket EBC (slotted/dimpled) from OEM blanks. The two lil' set screws that keep them attached to the wheel hubs...yeah, those screws keep snapping off their heads
. Go figure
. There is a little [fwd/rvs] play in the rotors as they set on the lug studs. "Clank...Clank"
Since I can reproduce the sound manually by shifting the slight play in these rotors, I'm either living with it...or awaiting that $1400 invoice
Dunno what else to do... I suppose I could replace my rear rotors (for ones that are not slightly "wallowed" out around the lug studs
. Go figure
. There is a little [fwd/rvs] play in the rotors as they set on the lug studs. "Clank...Clank"Since I can reproduce the sound manually by shifting the slight play in these rotors, I'm either living with it...or awaiting that $1400 invoice
I had that noise early on (5k) and it only seemed to happen when moving in reverse or starting out real slow. I took it in to my buddy who is a Honda mechanic and he sprayed some sort of lube in around the axle nut area and it fixed it. Not sure if it's the same issue, but worth checking out.
I just fixed mine @ 56k miles. The left rear wheel bearing was going out. The noise wasn't a clicking like CV joint gone bad but more consistent with wheel speed at any low speed on acceleration and deceleration after the car had been moving for a couple of miles. Oh what fun getting the outer race off the spindle. The race had spun on the spindle a few times. Not enough to destroy the spind;e, but enought to know I am going to buy another if this happens again. I now own a hydraulic press. I had to put in the longer wheel studs anyway, so I guess it was a good learning experience.
Scott
Scott
