Clutch Softness
Old Mar 26, 2008 | 10:10 PM
Ryani87's Avatar
Default Clutch Softness
Hey,
My '01 w/58k has a weird issue. Intermittently (in no regular interval) my clutch all the sudden goes soft. For 90% of the time the clutch has normal resistance, but every so often the clutch feels like stepping on a marshmallow. Sometimes it stays soft (like stepping on air) for a few hours, then gets back to normal resistance. The problem never lasts more than a day, but happens at random times. Has anyone had this issue? And if so, what's the problem? There is never any grinding or signs of slipping. I have an aftermarket warranty, so if it's coved i'd like to get it fixed relatively soon.
I've done a search with no conclusive results, some say it might be a slave cyl. Anyone know what the problem is?
Old Mar 27, 2008 | 03:02 AM
Jack_in_the_Box's Avatar
have you checked your clutch fluid?
Old Mar 27, 2008 | 04:35 AM
Skatethesea's Avatar
maybe your car just isnt attracted to you anymore!?
Old Mar 27, 2008 | 05:02 AM
nightcrawler7188's Avatar
^^i was thinking the same thing
i think you should check your master cylinder for leaks before the slave. also bleed your clutch fluid.
Old Mar 27, 2008 | 05:16 AM
lYellowDragonl's Avatar
i would also agree might be some leaks or holes in your lines
Old Mar 27, 2008 | 07:19 AM
2slow's Avatar
I think I have a very similar problem. My clutch feels almost too hard sometimes and then randomly it will suddenly get really soft. Like the OP, it only stays soft for less than a day. When it's hard, it sometimes feels sticky and makes somewhat of a rubbery squeak. I've always assumed something needed lubed, but since everything still worked ok, I figured it must not be serious (yet).
To the OP, let me know if you find anything out.
To everyone else, keep your perverted comments to yourself. I know what you're thinking I'm talking about my clutch... I swear!
Old Mar 27, 2008 | 08:55 AM
MitsukillinS2K's Avatar
i agree. bleed the lines and then check all the hoses/lines
Old Mar 27, 2008 | 09:01 AM
Hobbs5313's Avatar
Originally Posted by 2slow,Mar 27 2008, 10:19 AM
I think I have a very similar problem. Mine feels almost too hard sometimes and then randomly it will suddenly get really soft. Like the OP, it only stays soft for less than a day. When it's hard, it sometimes feels sticky and makes somewhat of a rubbery squeak. I've always assumed something needed lubed, but since everything still worked ok, I figured it must not be serious (yet).
I was thinking Viagra should fix the problems.
Old Mar 27, 2008 | 09:27 AM
w1ngman's Avatar
Damned mechanic added some salt peter to your clutch fluid
Old Mar 27, 2008 | 02:12 PM
tacocat's Avatar
Not enough foreplay?
