Gear install
Old Dec 21, 2005 | 07:06 AM
move_right's Avatar
Default Gear install
I'm wondering if anyone knows a reliable person to install some 4.44 gear in my s2k. Also does anyone here know how to or know someone who can install the yellow box? I would prefer someone who has done it before so I can avoid the CEL's some folks are getting.
Old Dec 21, 2005 | 07:11 AM
move_right's Avatar
While I'm asking questions: does anyone know if you have to lift the motor to install a Hondata heatshield intake manifold gasket? Yes I would be looking for some help on this too.
Old Dec 21, 2005 | 07:24 AM
4theheckof_it's Avatar
You dont have to lift the motor to install the Hondata Intake Manifold gasket. It's on the top of the engine. I've removed and replaced the intake manifold a few times. If you have no idea what you are doing, then I would suggest you have someone do it for you. It is a pain in the ass and pretty tedious. But it does keep your engine running a lot cooler.
Old Dec 21, 2005 | 10:45 AM
papa5murf's Avatar
you can get hardtopguy to install the new gears into a diff.. (comptech housing) and have it sent to you.. then you send them back your diff from your car.... and get your core charge back....
swapping the actual diff is quite easy... but the installation of the gears is where it gets technical....
as for the yellow box... you'll probably have better luck asking someone in the under the hood section... i've heard it's quite easy to do if you have any knowledge of electronics.... but you do have to set it up which will require a gps system... or a buddy driving next to you to adjust the settings on the yellow box...
Old Dec 23, 2005 | 09:29 AM
mwilly00's Avatar
I'm in Porstmouth VA and looking for someone to install my gears also. Any ideas?
Old Dec 23, 2005 | 05:33 PM
Scot's Avatar
JE import in towson maryland?
ap1son
30
May 6, 2008 02:00 PM
NSRsinfuLangeL
Feb 28, 2006 11:17 PM
BahrainONE1
Sep 11, 2005 08:42 AM
mice
Apr 25, 2005 08:56 PM
Russ
South Florida
Jun 23, 2004 09:42 AM
