View Poll Results: Which of the following brake system setups from gofastlab should I go with?
Stoptech Stage 2 Slotted brake upgrade (details in my post)
0%
My own setup (details in my post)
33.33%
Other setup...Please state parts/explain
66.67%
Voters: 3. You may not vote on this poll
Greetings+brake setup choice
Old Aug 30, 2005 | 09:54 PM
CaptKirk's Avatar
Default Greetings+brake setup choice
Sup everyone? Hows everything going? I see things have really slowed down in my absence I'll try to make a come back soon, but as of now, I actually had a real post with susbstance
I'm about due for a brake fluid and pad change right when I start driving so I thought that I might as well upgrade stuff. As of now, I was thinking of getting one of the following setups from gofastlab:
1) The stoptech Stage 2 Slotted brake upgrade
- this one contains: stoptech brake lines, stoptech slotted rotors for front and rear, axxis ultimate pads for front and rear, and 3 bottles of Motul RBF600
- all of this is for $649.00
2) My setup: Comptech brake lines, PowerSlot slotted rotors for front and rear, Hawk HPS pads for front and rear, and 2 bottles of ATE Super Blue/Gold
- all of this is for $711.90 with my Gold membership discount
Thanks in advance for any opinions/input on this matter
Old Aug 31, 2005 | 05:01 AM
Poindexter's Avatar
Greetings Naveed
I voted for other after my BBK experiences, and here is why.
1. My car was a daily driver
2. BBK rotors are more susceptible to environmental shifts - they warp easier
3. Racing pads can be noisy and may scare you on the regular street
4. Aftermarket companies aren't always reliable
5. Require more maintenance
6. Slotted and Drilled rotors aren't the easiest to resurface
On the other hand.
1. Done properly they can stop much better than stock
2. They look better
3. Someone will always be interested in buying them from you used
With that said, there is no better setup for a functional brake setup than stock. Your worries are only over regular things. If I do anything with my brakes, in the future, it will be a different set of pads.
Old Aug 31, 2005 | 05:33 AM
NO S8NT's Avatar
Originally Posted by Poindexter,Aug 31 2005, 08:01 AM
Greetings Naveed
On the other hand.
2. They look better
Old Aug 31, 2005 | 05:52 AM
Black Nugget's Avatar
Naveed -
I have a new set of OEM pads that I put on the car no more than 7k miles ago. This previous weekend my friend & I installed a set of Powerslot Slotted Rotors for both the front & rear and a set of Goodrich Stainless Steel Lines. I'll let you know how this works out when I pull car out for break-in period.
Old Aug 31, 2005 | 06:26 AM
TubeDriver's Avatar
If I was you I would:
1) Stoptech Lines
2) OEM rotors (slots just weaken things) You can also get blank rotors from Cobalt which is what I use on the track.
3) Valvoline Synpower DOT3/4 fluid
4) Hawk HPS pads are fine for street.
Old Aug 31, 2005 | 08:07 AM
CaptKirk's Avatar
[QUOTE=Poindexter,Aug 31 2005, 09:01 AM] Greetings Naveed
1.
Knoweyedea
Nov 16, 2012 09:36 PM
houstonn
Oct 19, 2010 11:44 AM
tre3478
Sep 30, 2010 06:05 PM
Clayman
Jan 30, 2004 03:38 PM
dwb1
Sep 14, 2001 02:23 PM
