help help help fast out of town problem
Old Jun 11, 2010 | 06:03 PM
01S2KBROSNAN's Avatar
Default help help help fast out of town problem
I just got into nj. And my cars is pulling right when I hit the gas and pulls left when I let off the gas.. please help asap.. if I can I wanna fix this tommorrow...
Old Jun 11, 2010 | 06:06 PM
NathanVencillS2K's Avatar
first thing i would do is check your tire pressures. if you have access to a floor jack the next thing i would check is rear toe arms. jack the car up and shake down all the wheels make sure nothing has worked itself loose. hope this helps and good luck, nathan.
Old Jun 11, 2010 | 06:17 PM
9000revolutions's Avatar
might wanna post in under the hood section. probably get more responses . good luck chris
Old Jun 11, 2010 | 06:21 PM
FISH22's Avatar
Sounds a lot like low tire pressure.
Old Jun 11, 2010 | 07:06 PM
It was an all of a sudden thing.. 3 hour ride it was fine till the last twenty..
Old Jun 11, 2010 | 07:14 PM
C Ory's Avatar
Definitely check the rear tire pressure, as stated before.
Old Jun 11, 2010 | 07:26 PM
.eric.'s Avatar
Rear control arm bushings OOC?
Old Jun 11, 2010 | 07:40 PM
OOC????
Old Jun 11, 2010 | 08:06 PM
.eric.'s Avatar
Originally Posted by 01S2KBROSNAN,Jun 11 2010, 11:40 PM
OOC????
Sorry, I'm using Navy jargon again.....
OOC = out of commission.
Old Jun 11, 2010 | 09:00 PM
WarrenW's Avatar
Brake caliper sticking?
