The Official I need moparacker's help thread!
This is a good place to coordinate mini mod days with the Hampton Roads S2Ki Mid-Atlantic crew chief - Tony (moparacker).
Post up here if you need help, so Tony can keep track of these things - and anyone who wants to help please post here too. I'll try to keep this first post updated.
Tony is keeping the second post of this thread as his schedule/calendar and I'll be cleaning things up as he requests.
First off, please don't whore in this thread.
General rules of the garage
-If there is something you need help with or just want me to do, post it. I will do some simple things as a friend, but something more involved might require a donation.
This can be discussed before hand elsewhere.
-If you don't know where my house is, shoot me a PM.
-If you want beer, YOU have to bring it. Just don't get too crazy.
-There is a pool in the backyard. If you feel like slacking off, then take a dip. Suits are required for guys.
Now, on to the simple stuff.
What to bring with you:
Oil changes
- Oil
- Filter
- Drain plug crush washer
Anything involving brakes
- Brake clean
- Brake fluid (depends on what is being done)
I have drain pans, funnels, rags. BUT any fluids that are required, you need to bring!
I have 4 jack stands. I can't see there every being a need for more than two cars requiring them at the same time.
This can be discussed before hand elsewhere.-If you don't know where my house is, shoot me a PM.
Oil changes
- Oil
- Filter
- Brake clean
These are some things I have done to some local cars. If I've worked on your car and its not listed or if you know of the date I've worked on your car, please post.
My car
- X-brace (12/03)
- Top down while rolling mod (TDWRM)
- Coilovers (3/12/04)
- Cusco 3 piece (3/12/04)
- Exhaust system replacement (x2)
- Hondata intake manifold gasket (7/23/04)
- Mr. Alex engine damper
- Lucid rear panels
- Front sway bar
ACLR8:
- Honda OEM front lip install
- Wilwood Big Brake Kit (5/29/04)
Black Nugget:
- Exhaust stud replacement
- TDWRM
- Rear plastic window replacement (6/11/04)
- Rear diff service (6/28/04)
- Tein coilover install (9/9/04)
- Spoon radiator hoses, thermostat, fan switch (9/12/04)
- Hondata intake gasket (9/12/04)
- Spoon thermostat removal
- Smaller supercharger pulley (Craptech S/C)
- RC 650 fuel injectors and clips
- AEM fuel pressure regulator
- AEM EMS with wideband o2 sensor (no tuning performed be me)
- 3.5 bar map sensor
- Rear diff and axle removal (to be reinstalled with stonger units at a later date)
- Carpet removal (to be replaced with black carpet at a later date)
- Engine head removal (to be reinstalled after it is recieved back from the machine shop)
C45P312:
- Rear diff fluid change
- TDWRM
- Rear diff swaped with dave22's
- Mechanical O2 sensor trick performed
- Spark plug replacement
CHIX RULE:
- Front sway bar (7/8/04)
dave22:
- Cusco 3 piece
- Supercharger belt and Honda acc belt replacement (x2)
- TDWRM
- '02 style glass top on '01 car
- Removal of Spoon radiator hoses, thermostat, fan switch (9/9/04)
- Test pipe with mechanical O2 sensor trick performed
- Removal of supercharger unit/aftercooler for painting
- Oil squirter bolt upgrade
- Removal of entire Vortech supercharger setup (S/C unit, fuel pump, fmu, aftercooler, electronic control unit, oil pan swap)
- Rats nest of the ECU wiring harness repaired
- Rear diff swapped with C45P312's
- Rear inner CV joint buckets swapped
Hatty Matty:
- Top replacement (6/30/04)
Hokie_S2K
- Cusco U-brace (6/20/04)
- TDWRM (6/20/04)
jnn4v:
- Top replacement (10/15/05)
MarkW
- Installation of entire Vortech supercharger setup ( S/C unit, fuel pump, fmu, aftercooler, electronic control unit, oil pan swap)
- Supercharger belt replacement
Poindexter:
- Speed X-Brace (12/03)
- Busted wheel locks off (12/03)
- TDWRM
- Comptech/Koni coilover setup (5/29/04)
- Exhaust removal and returned to stock
- Sway bar swapped for stock unit
ricosuave
- Tein coilover install (6/20/04)
- TDWRM (6/20/04)
s2k_PikeStyle
- Cusco U-brace (7/14/04)
- Front sway bar (7/14/04)
tenblade2001:
- TDWRM
- Cusco U-brace
- Front sway bar
- Koni install (6/26/04)
- Cusco 3 piece
- Mugen cooling mods
w1ngman
- '02 style glass top on '01 car (7/5/04)
Cars other than the S2000
Audi S4
- H&R Coilover install
- H&R front and rear sway bars
- Turbo bi-pipe (y-pipe)
BMW M3 (E46)
- Ground Control coilovers
- Front lower control arm bushings
- Front lip install
My car
- X-brace (12/03)
- Lucid rear panels
- Front sway bar
ACLR8:
Black Nugget:
- TDWRM
C45P312:
- TDWRM
CHIX RULE:
dave22:
- Cusco 3 piece
- TDWRM
Hatty Matty:
Hokie_S2K
- TDWRM (6/20/04)
jnn4v:
MarkW
Poindexter:
- TDWRM
ricosuave
- TDWRM (6/20/04)
s2k_PikeStyle
tenblade2001:
- TDWRM
- Cusco U-brace
- Front sway bar
- Cusco 3 piece
w1ngman
Audi S4
BMW M3 (E46)
- Front lip install
tony what fuel washers do we need??
Between you, dave and me, whoever gets to it first should just get all three of ours plus a couple spares.
We now have all 3 Hondata gaskets . . . . . .coolant isn't a problem although we also need some redline water wetter.
just my opinion. If you let me know I will just get 'em from joe. But I need a part number or good description.
Between you, dave and me, whoever gets to it first should just get all three of ours plus a couple spares.We now have all 3 Hondata gaskets . . . . . .coolant isn't a problem although we also need some redline water wetter.
