please help! emission problem...
Old Nov 15, 2009 | 04:03 PM
xervous36's Avatar
Default please help! emission problem...
Code: P0497 (EVAP System Low Purge Flow)
AP2 05 NFR
I got this a few days ago. Anybody had a similar problem?
I've tried to look for those loose hoses or cracks on the canister..and everything else in between, i can't seem to find the problem.. I'm stuck! My CEL is on.
What should i do? what part/s should I fix/replace to fix the problem?? where would that be located?
any help would be greatly appreciated...thanks
Old Nov 15, 2009 | 04:50 PM
yeaitsahonda's Avatar
Usually (i have never done a S2K, but with most other cars) a low flow code is due to the EVAP Purge Solenoid sticking closed.
Old Nov 15, 2009 | 05:36 PM
Budman05's Avatar
David is a real mechanic. Heed his advice.
Old Nov 15, 2009 | 06:12 PM
Thanks Lou.
OP: EVAP codes are some of the harder codes to diag. You may want to find a shop manual to read before you start replacing parts. Then you can test them first and know for sure that you solved the problem and didn't waste money on parts that worked as they should.
Old Nov 17, 2009 | 04:12 PM
xervous36's Avatar
thanks
Old Nov 17, 2009 | 05:10 PM
C Ory's Avatar
P0497 EVAP Canister System Low Purge Flow
Possible Causes
* Check the fuel filler cap installation (verify that it is tightened until it clicks)
* Check for leaks or restrictions in the canister purge vacuum line between the canister purge
valve and the intake manifold
* Check the vacuum line from canister to the solenoid for leaks
* EVAP canister purge valve has failed
* FTP sensor connector is damaged (check pins for damage, and for moisture)
* Purge solenoid connector is damaged (check pins for damage, and moisture)
* Vent solenoid connector is damaged (check pins for damage, and moisture)
zzz36
Apr 3, 2022 08:27 PM
andrew87890
Nov 1, 2013 10:18 AM
dryoung
Apr 7, 2008 03:06 PM
glagola1
Feb 19, 2008 06:10 AM
