replacing wheel studs
Old Jul 5, 2006 | 08:53 AM
goldenfri's Avatar
Default replacing wheel studs
One of my wheel studs is messed up and needs to be replaced. I looked in my Helms and didn't see anything about replacing one without taking the whole hub off. If thats the case, I need to take it somewhere and does this car require a press to replace it?
Thanks for any info.
Old Jul 5, 2006 | 09:20 AM
gfacter's Avatar
You are going to need a new hub and if its a rear hub a new bearing, as the bearing comes apart when you press out the hub from the spindle.
They will need a bearing press.
The studs are pressed into the hub, I guess if you could get the hub off cleanly you could just press in a new stud.
I have a old hub here with good studs you are welcome to have it. Actually one of the studs fell out,.
Old Jul 5, 2006 | 09:45 AM
goldenfri's Avatar
Thanks for the info, thats kind of what I was afraid of... so it sounds like I have to goto a real mechanic or the dealer or somthing
SuperKool
Feb 11, 2014 08:32 AM
B.Money
Mar 25, 2011 07:48 AM
Ro_Ja Boy
Mar 12, 2011 07:05 AM
YuriArts
Oct 22, 2007 01:33 PM
Highlift
Oct 2, 2006 11:15 AM
