Tranny Issue
Old Jun 23, 2010 | 01:06 PM
Roflcopter's Avatar
I had a problem getting it in gear when it was cold for a while and my clutch had like no feedback whatsoever and had to push it to the floor to shift. When I swapped my clutch fluid, it came out it was black and there was hardly any in there. Performed great after I did that.
Old Jun 23, 2010 | 03:08 PM
Insert Name's Avatar
Bad Master or Slave. Check both for leaks. Bleed the system and recheck. If it makes no difference i'd start swapping parts.
Old Jun 23, 2010 | 04:35 PM
True_Blue's Avatar
I agree - clutch fluid or system issue. Danzilla had a similar problem last year and it was down to clutch fluid level.
Old Jun 23, 2010 | 05:14 PM
C Ory's Avatar
The only thing deterring me from saying its a fluid problem is that you say it only happens when you first start the car. If it was a master/slave cylinder problem, it would happen every time.
It sounds more like an internal problem.
Old Jun 23, 2010 | 06:51 PM
01S2KBROSNAN's Avatar
i still think its the TOB
just sayin
but idk i could be as off as some
Old Jun 23, 2010 | 07:36 PM
Roflcopter's Avatar
That's how mine was, then I changed the fluid and it was fine.
Old Jun 23, 2010 | 08:42 PM
ninja05's Avatar
Thanks for all the responses guys!
I checked my clutch fluid today and it was a bit low, so I topped it off. (it was pretty much a little lower then the min level.) We'll see what happens tomorrow morning after I start her up...
I also plan on bleeding the clutch as suggested, within the next week or so, and hopefully that would help solve the problems as well.
I never thought that it could be a fluid problem, but it makes sense, since my engagement point on the clutch seemed to get lower within the last month or two. So perhaps it was from a lack of fluid, or as Matt suggested, air was getting into the system.
Hopefully, the $3 I spent on the fluid fixes the problem!!! LOL
Old Jun 24, 2010 | 04:13 AM
C Ory's Avatar
Try pumping the clutch pedal a few times before you even start the car.
It sorta makes sense that in the morning there was a liilttle less pressure, but as you use the clutch it starts building pressure back up.
I recently had to change my clutch master and slave cylinder because of a small leak from the master. Ran it out of fluid and had a lot of air in the system.
Old Jun 24, 2010 | 05:22 AM
you probably wont notice much of a difference until after you bleed the system. If there is air in it already you are not going to alleviate the problem until you bleed it out.
Old Jun 25, 2010 | 07:55 PM
RedY2KS2k's Avatar
just sayin
Pulled a lot of transmissions because of bad throwout bearings, have you?
